Tint question!
Old Feb 15, 2006 | 11:46 AM
ORANGEBROTHERS's Avatar
ORANGEBROTHERS
Default Tint question!
Just had my 02 coupe tinted and they did not tint the top of the back window. They claim you should not cover the dots on the defroster because the tint will not last and will eventually come off. Is this true????
Old Feb 15, 2006 | 11:58 AM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
No, they just did not have the skills to do it.
Old Feb 15, 2006 | 12:34 PM
ORANGEBROTHERS
Your window top section is diffrent then mine. I have an 02 and not sure why it has a top section filled with dots.
Old Feb 15, 2006 | 12:41 PM
ORANGEBROTHERS
What film did you use? I'm told solar guard might work but the performance tint that I'm using will not stick to dots.
Old Feb 15, 2006 | 01:01 PM
freemanjc's Avatar
freemanjc
No problem with mine! I used a metalic tint film!
Old Feb 15, 2006 | 01:06 PM
ORANGEBROTHERS
They tell me metalic tint won't last on dots and will eventually peel or start to come off. How long have you had yours?
Old Feb 15, 2006 | 01:29 PM
DPG's Avatar
DPG
St. Jude Donor '06
dont you know that girls like guys with skills....gosh!
Sorry had to get that quote in there. A goood installer should be able to cover the dot matrix and get the bubbles out of there as well
Old Feb 15, 2006 | 01:34 PM
ORANGEBROTHERS
They told me the metalic based performance tint just won't stick to dot matrix. Do you know of another film that will?
Old Feb 15, 2006 | 02:10 PM
WWK888's Avatar
WWK888
I think you need to check with different installers. Any type of tint can be applied over the dots if they know what they are doing. My installer has done numerous vehicles (both Vette and non Vette cars) with no problems. My tint has been on for over 3 years and looks perfect. Good luck!
Old Feb 15, 2006 | 03:17 PM
mchaskell's Avatar
mchaskell
Cruising
Just went through this today with my installer (having the tint removed that was on the car when I bought it). He said that they use vinyl or black paint on the dots. The existing tint (from another vendor) used vinyl on the dots.
Old Feb 15, 2006 | 03:22 PM
ORANGEBROTHERS
Yeah my installer said I should try vinyl. Have you seen what it looks like with vinyl? Is it nice?
Old Feb 15, 2006 | 03:40 PM
mchaskell's Avatar
mchaskell
Cruising
Default Vinyl
Mine had the vinyl on it. Personally I could not tell what type of tint it was. The installer had to pick at it with his finger to tell if it was paint, vinyl or film. I have been going to this guy for 20 years and I trust what he says. The only thing about using two types of film it that there is a seam line between the films.
Old Feb 15, 2006 | 04:26 PM
g2103320's Avatar
g2103320
My installer used Formula One metalic tints made by CPFilms. He went right over the dot matrix on my '02. All Formula One tints come with a Lifetime warantee against chipping, peeling, or bubbling.
Old Feb 15, 2006 | 04:28 PM
ORANGEBROTHERS
Thanks!
Old Feb 15, 2006 | 05:36 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
It's the same rear window. They all have the dots.
Old Feb 15, 2006 | 05:56 PM
Nithros's Avatar
Nithros
St. Jude Partner since 89
St. Jude Donor '09
My installer sanded them down. That worked pretty good but I wanted him to do the vinyl like another guy did on my kid's Honda which came out extremely well.
Old Feb 15, 2006 | 07:07 PM
ORANGEBROTHERS
BTW, anyone know how long it takes for all those small bubbles to disappear?
To Tint question!
Old Feb 15, 2006 | 08:27 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
His window has all the same dots that my 2002 does.
Look again...
Old Feb 15, 2006 | 08:50 PM
ORANGEBROTHERS
Look again...
It's just hard to see but I guess so.
Old Feb 15, 2006 | 09:24 PM
Humanoid 2.0
I have the dots like all Vettes do, the guy just knew what he was doing, that is why it hard to tell from the photos. He used one piece, computer cut. It is 35%. It is Llumar brand tint.
