Laughable GM dealer
Old Feb 18, 2006 | 10:32 AM
lionfan90's Avatar
lionfan90
Default Laughable GM dealer
I bought Borla Stingers (used off of Ebay) for my black '01 coupe. The seller says that they don't come with the gaskets, which I would have replaced anyway, so I stop by my local GM dealer to pick up the new gaskets. Just for fun, I asked how much they would charge to install the cat-back Borlas on my car. Well, the lady I talked to said, "Let me go check with the technicians in the shop".
So I paitiently waited for her to come back and she says, "We charge $75/hour for labor, and Joe Schmo (name withheld) figures about $337". She continues, Joe says that they take a lot of tweaking to get the tips aligned and he has done a lot of them in the past, so he knows".
I suppressed my initial urge to and walked out with the parts I bought.
So, my question to all the folks out here who have installed their own exhausts, 4 1/2 hours????? Is that or what?
I'm figuring an hour, tops, if you run into a small alignment problem. I'd do it myself, If I could get the car up high enough, but I've heard that you should raise it up a minimum of 30-36 inches, which I can't do at home.
Old Feb 18, 2006 | 10:37 AM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
$100 at Mineke, only issue was using boards to get easy angle to get the car on their drive in lift. Less than an hour, I had the directions from Borla printed out and went over the install before they started.
Beer
Old Feb 18, 2006 | 10:40 AM
rws.1's Avatar
rws.1
Uh,
We did it in a club member's driveway...
Did the floor jack lift one car at a time
took the Borla's off his, put on Z06 Ti's
Took the stock off mine, put the Borla's on,
Went over to Autozone to buy the gaskets we forgot about.....
All done in about 3 hours......
Old Feb 18, 2006 | 10:41 AM
VolFan615's Avatar
VolFan615
Yellow C3/C5
St. Jude Donor '05-'06
I had a local muffler shop install my Ti exhaust for $65. I would have only taken him about an hour if he hadn't of lost one of the hanger bolts up in the the bumper support. He spent another hour almost trying to fish it out with a magnet
Old Feb 18, 2006 | 10:42 AM
Baron138's Avatar
Baron138
I had mine done in Carlisle. They had my stock system off, and the Borlas on and the car off the lift in about 20 minutes! The system and the install was $900. Tips are straight and no leaks. Granted those guys had done a bunch already, and were good. You did the right thing walking out of the dealer .
Old Feb 18, 2006 | 10:50 AM
lost's Avatar
lost
I paid a local shop $40 for my ZO6 ti's, took him 20 minutes including aligning the tips, answering the phone, etc[boss was at lunch].
Old Feb 18, 2006 | 10:52 AM
WKMCD's Avatar
WKMCD
Sounds about right to me. The average owner can do it in about 1.5 hours or less with a buddy. I would think the "highly trained technicians" at the dealer ought to take 4.5 hours.
Old Feb 18, 2006 | 10:54 AM
scoaman's Avatar
scoaman
My dealer (Chevy) did the exhaust with the crossover pipe change for $175 and they warranty it.
Old Feb 18, 2006 | 11:15 AM
CUlookin's Avatar
CUlookin
ECS did mine with my header install in about 30 minutes... And that included the tweaking of the tips... Dealership = BS!
Old Feb 18, 2006 | 11:30 AM
BWP 5P's Avatar
BWP 5P
Veteran: Marine Corps
St. Jude Contributor
1 hour tops....unless his name was Dilbert
Old Feb 18, 2006 | 11:32 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
some good deals out there !
I had my Vararam, high flow duct, 160. thermostat, Ls6 manifold, Kooks headers, X-pipe, and GHL exhaust installed for $700.00 at a dealer in NJ. ( when my car was being re-ringed. )
They also offered to but new heads on the car included for the $700 if I wanted to, but I couldnt get a set quick enough.
Old Feb 18, 2006 | 12:00 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
My Chevy installed mine in an hour and charged me $90.
Old Feb 18, 2006 | 12:05 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Did my own in about 1 1/2 hrs. Could do a second set in 45 min.
Old Feb 18, 2006 | 12:06 PM
jrose7004's Avatar
jrose7004
$65.00 at a local muffler shop here and it took him about an hour!
Old Feb 18, 2006 | 12:30 PM
KemahC5's Avatar
KemahC5
Default Must have included the "test drive".
Probably included about an hour or so for the "test drive".
Old Feb 18, 2006 | 12:34 PM
BlownV6's Avatar
BlownV6
I've done a stinger install before.
30 Mins to cut off the 2 stock mufflers
15 mins to unbolt the stock pipes
30 mins to install new stingers pipes
4 hours is bull**** and the tips don't take that much time to fix
Old Feb 18, 2006 | 01:09 PM
Lancer033's Avatar
Lancer033
I did the same thing when I got my Stingers. Dealer wanted $325 to do it. Local shop did it for $75.
To Laughable GM dealer
Old Feb 18, 2006 | 03:10 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
It's an hour job at best.........
Old Feb 18, 2006 | 03:27 PM
sailohio's Avatar
sailohio
Old Feb 18, 2006 | 05:03 PM
Steveo1c5's Avatar
Steveo1c5
I paided $500, for my Full polished Borla's, and installed them myself in 45 min. in my garage with a set of ramps and a jack. Anything over $75 is a rip off IMFO, any shop with a competent worker shouldn't take more then a hour to do a cat back system. It's the old "you have a vette you have money" so we can charge 5 times normal.
