DIY Flush tail light link?
Links or info please..
Pre thanks!
Thank you!
I also used different weather stripping. I couldn't find the size mentioned in the DIY thread at either Home Depot or Lowes, so I used Automotive weatherstripping that I found at HD and it was 5/16 X 19/32 and ribbed, but it worked just fine. The job took me about a half hour and I think it looks great. Here are a few pix...
Flush Mounted Tail Lights
(6) 1" L X 1/2 W X .194" Hole Size Nylon Spacers
(6) 1/4" L X 1/2" W X .194 Hole Size Nylon Spacers
(8) #8 x 2" Zinc Pan Head Screws
(1) Frost King Rubber Foam Weatherseal 3/8" W X 5/16" Thick x 10' Long (Adheasive backed)(I got the black weather stripping)
Simply unscrew tail lights, clean, put weather stripping around the tail light (where the red casing meets the black casing of the light) insert new screws and spacers on back side, screw back into mounting hole.
-The two center lights get one 1" spacer on each screw.
-The outside lights get three 1/4" spacers on each of the outer most
screw
-The inner screw on the outside most lights get one 1" spacer.
-Fit so the weather stripping looks good and screw them back in!
1" spacers $4.77
1/4 Spacers $3.42
Weather stripping $3.98
Pan head screws $.98
Willfulone
