Optima Batteries
Feb 22, 2006 | 08:20 AM
Optima Batteries
Which Optima batteries are you using? Do they make one with a side post only?
Where is the best place to buy?
Thanks!
Feb 22, 2006 | 08:29 AM
batteries
Thanks!
red top s ,at ADVANCE AUTO
Feb 22, 2006 | 08:38 AM
Quote:
Feb 22, 2006 | 08:41 AM
I use the Red Top and it has side posts. I got mine at Costco for $100
Feb 22, 2006 | 08:45 AM
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Go to the source for info....
http://www.1st-optima-batteries.com/
And
CostCo for Red Tops
Feb 22, 2006 | 09:02 AM
Costco. Lowest price, good service.
Feb 22, 2006 | 09:04 AM
Feb 22, 2006 | 09:06 AM
St. Jude Donor '05-'06
Red Top from Costco.. with side post.
Feb 22, 2006 | 09:18 AM
Can't beat Costco. Red top
Feb 22, 2006 | 09:32 AM
Cruise-In V Veteran
Cruise-In VI Veteran
Costco if you have a membership
Feb 22, 2006 | 10:52 AM
Quote:
Feb 22, 2006 | 11:48 AM
St. Jude Donor '09
with everyone here. Optima RedTop 34/75 or a 34/78. Either will work great. The 34/78 has a bit more CCA's.
If you buy a 34/78 you can buy a cover from Optima that hides the top posts. About 14 bucks or so.
Feb 22, 2006 | 11:54 AM
You must go yellow top if you plan to have a decent stereo with some boom!
Feb 22, 2006 | 12:16 PM
Quote:
Does a 34/78 fit all year C5's?
I'm especially interested in 2002's...
Feb 22, 2006 | 03:05 PM
How about the same in a 2000?
Feb 22, 2006 | 04:29 PM
St. Jude Donor '09
Quote:
I'm pretty sure it will. The battery tray in my '01 certainly is big enough. I've read posts where people have had to put a different lock down piece on the 78's. Not sure though. I have a 34/75 and it fits/locks down with the OE equipment. Unless you are running in really cold places or have a massive stereo system the 34/75 will work fine. It has more CCA's than the original 75 series that came with the car.
Feb 22, 2006 | 04:35 PM
I recently dropped the Optima RedTop 34/78 into my 04' vert. No problem with the fit, but the OEM hold down clamp wouldn't work. I used the one supplied with the battery for GM cars and it worked perfectly.
Feb 22, 2006 | 05:38 PM
Optima Red-Top. Advance Auto Parts 124.95.
Feb 22, 2006 | 05:57 PM
St. Jude Donor '07-'08-'10, '14
Red top 34/78... $114 at Pep boys...
