exhaust that pops?
Feb 22, 2006 | 01:18 PM
exhaust that pops?
Im looking for an exhaust that pops when i deaccelerate (sp?). Especially when I am using the engine to hold me back on a hill.
Feb 22, 2006 | 01:26 PM
My Z06 exhaust pops on decel. right around 2200 rpm if I remember correctly. Most catbacks should pop some what unless you replace the x-pipe. The x-pipe is supposed to reduce the popping by equalizing the exhaust gases! Good luck with your search!
Feb 22, 2006 | 01:28 PM
Just get a performance system with no x-pipe and you'll get the pop. You'll also get a motorboat sound but you might like it!
Feb 22, 2006 | 01:31 PM
Quote:
I'm down with the motorboat sound as long as it doesn't completely drown out all other sounds at cruise.
Feb 22, 2006 | 01:32 PM
Feb 22, 2006 | 01:43 PM
My Borla's twin tip stingers with factory H pipe also burbble on decel.
Feb 22, 2006 | 01:44 PM
My B&B PRT's do that as well.
Feb 22, 2006 | 01:47 PM
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
almost all of the aftermarket louder exhaust do that.. my SLP's do it a lot
Feb 22, 2006 | 02:00 PM
Ahh the great gurggle... Music to my ears
I have a Corsa Indy Exhaust installed at it has a fantastic popping/gurggling sound-DK
Feb 22, 2006 | 02:09 PM
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
First try removing the factory H-Pipe and plugging the holes. That may give you what you want at no cost at all.
Feb 22, 2006 | 02:37 PM
Crazy popping with the Corsa Ti's/no mufflers. Awesome!
-Kirk
Feb 22, 2006 | 02:59 PM
Don't get an X-pipe and any aftermarket exhaust will do it
Feb 22, 2006 | 03:01 PM
all c5s pop on decel even with stock exhaust it is caused by the change in firing order on the ls1. x pipe will eliminate most of it and will change that motor boat sound
Feb 22, 2006 | 03:07 PM
Borla XR-1. Pops a lot. I love it
Feb 22, 2006 | 03:10 PM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
My Borla stingers with LG LT w/o cats do that a
LOT
Feb 22, 2006 | 03:13 PM
"Ahh the great gurggle... Music to my ears I have a Corsa Indy Exhaust installed at it has a fantastic popping/gurggling sound-DK"
+1 on that
Feb 22, 2006 | 03:16 PM
Got Pop?
My B&B Bullets with the magnaflow X-pipe pops all the time under deceleration. Sounds great!
Feb 22, 2006 | 03:25 PM
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Quote:
B&B all the way. They pop like a ***** when you let off the go pedal.
Feb 22, 2006 | 03:42 PM
#1 most important thing to remember no matter which system you go with:
NO X-PIPE OR H-PIPE
Feb 22, 2006 | 04:05 PM
Mine do it even with the x-pipe, but probably not as much as they would without it.
