lowered car , need help
Old Feb 23, 2006 | 08:47 PM
motomafia's Avatar
motomafia
Default lowered car , need help
adjusted the car lower,,, doesnt seem to be that much lower really.... matched all the threads to the same... Is it a big deal if they arent all PERFECTLY the same amount of threads?
Old Feb 23, 2006 | 08:48 PM
Swany00's Avatar
Swany00
Veteran: Marine Corps
it'll settle after a day or two, drive it around to help out. Did you lower it all the way, then back off a few?
Old Feb 23, 2006 | 08:51 PM
motomafia's Avatar
motomafia
Yea, but the " a few " part is what iam worried about... are exaact numbers not important? wil this not hurt my performance if it isnt perfect/
Old Feb 23, 2006 | 08:55 PM
mredden05's Avatar
mredden05
In the rear you "should" leave 2 threads showing....but I didn't it is only showing 1. In the front you can go all the way....
Old Feb 23, 2006 | 08:57 PM
motomafia's Avatar
motomafia
in the frount I just went until there was no space between the rubber boot and the metal... still iam just worried does this not have to be a exact science... also anyone with pics of what is should look like after mine seems high.
Old Feb 23, 2006 | 08:58 PM
TripleBlackxThree's Avatar
TripleBlackxThree
St. Jude Donor '07
It isn't the number of threads, but the height that needs to be uniform. Mine ended up slightly different on each side. Ideally you want the left side just a bit higher to account for driver weight.
I will take a bit to settle.
Old Feb 23, 2006 | 09:12 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
"rubber boot" What rubber boot? There was no rubber boot on my car in the front. What you do in the front is back the plastic spacer/bushing up into the threads in the spring (IIRC).
Old Feb 23, 2006 | 09:25 PM
jrose7004's Avatar
jrose7004
After it settles for a couple of hundred miles get it aligned.
Old Feb 23, 2006 | 09:31 PM
ATI Performance's Avatar
0ATI Performance
Former Vendor
Technically, the correct way to adjust the ride heights is to balance the corner weights at the nominal desired ride height, which takes a set of scales and a perfectly level surface. For a car only street driven, this is not a big deal and I would not worry about it.
Changing the ride height will also change the wheel alignment, and at minimum the toe should be rechecked.
Bob
ATI Performance Engineering
Old Feb 24, 2006 | 11:20 AM
motomafia's Avatar
motomafia
anyone have any before after photos with 17-18 wheels? what have you noticed on performance diffrances ? thanks
Old Feb 24, 2006 | 11:38 AM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
After removing the bolts from the front end, lowering rear with new bolts to -1.5. Pulled off jacks and it looked like a 4 x 4. The front gap must have been 5 inches between tire and fender.
A couple of miles and it will settle. I made adjustments on rear by measuring fender height. On mine, the bolt threads showing are different to keep fenders level.
Don't worry, you will like the change.
tt
Old Feb 24, 2006 | 11:50 AM
jackj's Avatar
jackj
give it some time!!!
Old Feb 24, 2006 | 11:56 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
it took about a week for mine to settle, back is just a tad lower than the front
Old Feb 24, 2006 | 03:35 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Took about a day of just driving around and I had no alignment issues and the car looked so much better!
Old Feb 24, 2006 | 03:39 PM
Z06HPISFUN's Avatar
Z06HPISFUN
St. Jude Donor '07
As you probably have found out already there's a ton of threads on lowering. After reading probably every one of them, I started to compile notes on what I thought was pertinent before lowering my car. The following is an excerpt from a thread I kept. Not sure who the "author" is.
"If you measure on the frame rails, just in front of the jacking puck holes in front and just behind the rear jacking puck holes the difference should be 4-5mm or 1/4 to 3/8" higher in the rear. DO not measure to the center of the fenders, Body parts are NOT equal."
Hope this helps.
Old Feb 24, 2006 | 03:44 PM
bigcypress's Avatar
bigcypress
i've always wondered if this is easily reversible,that is,to restore it to factory specs . thanks
To lowered car , need help
