DTE Brace
It can be done without removing anything but I can't imagine the PITA you will go through, especially without a lift.
I also highly recommend the brace.
I couldn't find step three in the manual.
Care to elaborate Cajundude???
Well i have 378 with BFG Drags and was thinking about a cam..... also close to a clutch job and figured i may install one then..... What HP range do you think you relly need one of these?
Ahhhh. I get it now.
might help above 600hp........braces break too
The greater the driveline shock from the power application, regardless of *any* available power output, the greater the chance of driveline deflection under load, which leads to an overload event and ultimately driveline failure. Additionally, stiff-sidewall, DOT approved drag radial tires will always transmit a significantly more amount of torsional shock directly to the differential, than would a non-DOT approved, soft-sidewall drag slick.
The differential and transmission cases in these cars are manufactured of a moderate-grade cast aluminum at best, which by nature, *WILL* metallurgically fatigue over time to the point of failure (especially drag racing abuses) and there is not one person that can overcome that very simple law of physics despite their deepest desires to do so otherwise. The sooner someone realizes that fact, regardless of what car they have, the easier it will be to accept when the driveline in *ANY* drag race car will break given enough time...
If you choose to race your Corvette, (or any vehicle for that matter) you *WILL* break something eventually regardless of what the components are manufactured of and who produced them.....
Our product was designed and engineered to significantly reduce the likelihood of catastrophic driveline failure that would otherwise also destroy the transmission with it if the internal components of the differential failed causing driveline fracture. Simplistic design and sound engineering enable it to do just that very well and it's success to date on hundreds of cars has been a supporting testiment to that fact to date.
Respectfully,
DTE
I'd recommend it.. it's a stout piece.
....even if its modded, you dont need one
