[Z06] Clock/ Battery issue
Old Feb 26, 2006 | 06:01 PM
dlrshort's Avatar
dlrshort
Default Clock/ Battery issue
Hi, my '02 Z06 maybe gets driven once or twice every couple of weeks. I notice that the battery drains down to 60-70% of full capacity causing it to slowly turn over. It does start, but if it sits for any time the charge will trickle away. Also, I have noticed that the clock will loose time as well. Could this be a symptom of the battery or do you think that it could be a separate issue? Thanks.
DS
Old Feb 26, 2006 | 06:05 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Battery.
I am guessing that your HUD also resets to the defaults.
Old Feb 26, 2006 | 06:34 PM
02bpdz06's Avatar
02bpdz06
From experience I can tell you it's a battery problem.
Old Feb 26, 2006 | 06:37 PM
dlrshort's Avatar
dlrshort
Do you think the clock is also a symptom of the battery?
Old Feb 26, 2006 | 06:57 PM
gsjack's Avatar
gsjack
Definite battery problem...
Buy a new battery and get yourself a battery tender.
Jack
To Clock/ Battery issue
