Oil Drip Mn6
Old Feb 27, 2006 | 08:26 PM
HERK's Avatar
HERK
Default Oil Drip Mn6
i have a 2000 c5 with 5500 miles on it .the tranny is leaking a little oil,mn6.is this a big job, and how much will it coast?
Old Feb 27, 2006 | 08:31 PM
racecar2001's Avatar
racecar2001
I know a few people will jump in here with the fact the left axle seal leaks. I had a small leak on my 6-speed and it was the shifter seal. Cost I can only guess at because mine was under warrantee at the time, but it was in the shop for a week.
Old Feb 27, 2006 | 08:36 PM
HERK's Avatar
HERK
it's not the seal,had it up on my lift .it's coming right from the center of the tranny.
Old Feb 27, 2006 | 11:34 PM
HERK's Avatar
HERK
ttt
Old Feb 28, 2006 | 07:17 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Not the seal?? Short of a possible hairline crack, I'm not sure what the problem would be. May want to post in the Tech section if you don't get more of a response here. Good luck
Old Feb 28, 2006 | 07:26 AM
DeeGee's Avatar
DeeGee
Just a thought but you haven't recently had it serviced have you?
I had mine done and the dealer over-filled the transmission oil. It vented until they drained it to the correct level.
Apparently it can also vent if driven hard (over 100 for a significant period) Guess what the dealer accused me of doing
To Oil Drip Mn6
