At first I was not sure about these. I emailed Maciek and expressed my concerns. He graciously said to install the pieces and if I was not happy he would gladly exchange them for me. The leather is top notch, my hesitation was with the stiching. I must say, after the install I am pleased. Here are a few pics.
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Rick, pieces look great...I think the stiching is subtle enough and is done with class. Curious about the centre console. Thing looks factory...how did you get it to fit so snug? Did you take the factory cover off?
I was looking at that also. Looks great. I was considering using them as well
I know what you mean. The pieces look a little sad before installation. Have to say it wasn't the most straight forward job I've done but I'm happy with my installation.
The leather looks a little pink in the direct flash. For real its much darker.
BTW I agree with the comments. Your fit looks subtle. Great job
looks great, i like the redline products. they are very reasonably priced and very good quality. i also like your nav system setup. it looks professionally installed.
I know what you mean when it comes to the stitching. To bad he couldn't find a better machine or thread to do the job. The leather is top drawer thought.
Thanks, Thats what I was going for. The plan is to redo the seats in black leather with suede inserts and yellow stiching to match. May also throw some of the black suede material on the lower doors and dash peices to pull it all together.
To answer the question on the console lid, I used double sided tape under the factory cover to hold it in place, this allowed me to strech it taught before screwing everthing back together.
looks good to me. i bought the shift boot and console cover and steering wheel cover etc in red and black from midamerica but sent them back cause it was all pink stitching...but i did note that the auto shift boot looked complicated to install, was it?
This was definately the hardest part. I had to cut he stock boot from the trim ring around the gear indicator and glue the replacement onto it. I used a gel superglue so I had to be careful not to get glue anywhere else. If you take your time its not to bad, and you have the original to look at.
I actually removed the mid america console cushion, it was not bad, but the piping on my was all discolored and dingy looking after a year or so. It was black with yellow piping.
