[Z06] Vararam Air Intake
Old Mar 25, 2006 | 07:15 AM
bbakerz06's Avatar
bbakerz06
Originally Posted by Mikey Z
k+n part # is 33-2522
Is it necessary to cut off the lip on the lower housing on the VR-1B system to make the k+n fit??
Old Mar 25, 2006 | 11:38 AM
straatien's Avatar
straatien
I'll be installing the Vararam on my '02. Too bad it doesn't work with the Tiger fascia.
Originally Posted by NPD337
I INSTALLED ONE ON MY 03 Z06 AND FELT A BIG DIFFRENCE. DID NOT EXPECT TO FELL ANY THING FROM JUST A INTAKE BUT YOU DO. THE QUALITY OF THE VARARAM DOES SUCK. AND ALL THE PLASTIC IS CHEAP NOTHING FITS PROPERLY BUT WITH A LITTLE FABRICATION YOU WILL BE HAPPY WITH THE SYSTEM.
I LOVE TO SHOUT!! CAN YOU HEAR ME!! I ALSO DON'T KNOW HOW TO USE SPELL CHECK!! Just teasing you NPD337. I think everyone has made the CAPS LOCK mistake at least once.
Old Mar 26, 2006 | 01:24 AM
TheDVS1's Avatar
TheDVS1
It shouldn't be necessary to cut either the K&N or the housing on the Vararam. I actually put some foam weather strip around the lip of the upper and lower housings to get a good seal. I then used a 1 1/2 inch putty knife and "shoehorned" the rubber lip of the K&N into the lower housing. Fits nice and snug, and doesn't throw NEAR as many codes on my '04 Z as the wimpy foam filter that came with the VR-B2. I was also getting some dirt into the TB with the foam filter, but with the K&N everything is nice and clean!
Old Mar 31, 2006 | 01:33 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Vararam is a nice concept and despite many fitment issues, I used to be a proponent.
However, after seeing first hand how their flimsy foam filter did not work I couldn't recommend this system to my worst enemy.
Hopefully they've made changes to the filter and addresses the fitment issues.
Old Mar 31, 2006 | 03:36 AM
03 Z-oh-6's Avatar
03 Z-oh-6
What's a good intake with good performance gains AND good quality with no fitment issues?
Old Mar 31, 2006 | 10:32 AM
shurite44's Avatar
shurite44
Take your time on the vararam install and it will fit fine. I have had two of them and they fit very well. Cajun has a how too that is very good to follow.
Old Mar 31, 2006 | 11:43 AM
2000BSME's Avatar
2000BSME
Originally Posted by HACKSAW
Local Corvette Guru Is Suggesting The Vararam For My 03 - Zo6 - Presently Stock.also Going To Make Some Computer Upgrades.
Feedback Please - Yes 0r No?
Vararam quality is better than the initial build quality components of the Corvette that you are putting it on. I saw excellent gains when I put one on my '99 automatic.
Old Mar 31, 2006 | 11:45 AM
2000BSME's Avatar
2000BSME
they have made changes. The new filter is a pleated unit that supposedly filters better and flows better than the foam one, cost: $50. I just ordered one.
Old Mar 31, 2006 | 03:01 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Originally Posted by Kappa
My friend had a Vararam and he said it felt much stronger up top. So we went to the dyno and it put out about 5whp more than the bone stock dyno. He took it to the local tuner and found that his injectors were running at 100% duty cycle! The Vararam was taking so much air that the computer couldn't adjust.
This does not make sense. The VR will not cause the injectors to run 100%. The only true solution to a 100% injector is a bigger injector.
Old Mar 31, 2006 | 03:56 PM
algZO6's Avatar
algZO6
he must of put the tornado on it as well.
Old Mar 31, 2006 | 04:06 PM
Kappa's Avatar
Kappa
I'm just telling you what I heard. Either way he still gained 22rwhp. Vararam is a good product.
Old Mar 31, 2006 | 08:57 PM
Power Shifter's Avatar
Power Shifter
Fourms shure have lots of opinions, so here's mine on the vararam. When installing the foam filter put it snugly in the LOWER section then put the cover on. I have seen a beach of s*it against that foam filter and not even any dust in the houseing after the filter. As far as quality of the vararam, people who are not familier with the vette think your running stock, so it's more than fine for me.
Ric
Old Mar 31, 2006 | 10:57 PM
  #33
KyleBst264's Avatar
KyleBst264
The vararam is the next thing the UPS truck is going to be bringing to my house.
Old Apr 1, 2006 | 12:59 AM
  #34
Z06-Goose's Avatar
Z06-Goose
Well, I hope you're right. I have a Vararam I'll be buying from a friend (VB2) and I'm already confused about the air filter issue. Let us know how this new/improved filter works for you. I was already thinking about getting the K&N filter, and doing the weatherstrip foam mod, which I'm not quite clear what to use, and what width and what not.
Please post up a review on this if you can. Thanks Goose
Old Apr 1, 2006 | 01:31 AM
  #35
shurite44's Avatar
shurite44
Vararam's new filter sounds like a good filter. I have not seen it though. A very well respected air filter company is now making it, but I can not remember the name. Sorry not much help there.
I used the old HP foam filter and did not have any problems. I think if it was also a daily driver I would switch out now. Use the foam filter at the strip and the pleated one for the street.
The foam filter was very high flow. Virtually no resistance. But it was probably not the most efficient filter, but I never had any TB horror stories happen to me.
I recommend the vararam just for the performance gains alone. It really does work quite well. Not easy to install but doable. I had a mechanic help me or I probably would have had fitment issues. But he took his time and it really fit well. After the install we did the pressure test they recommend and it worked. And that was it, no problems after that. Always sealed good. I washed the filter a lot and never had a seal problem.
Old Apr 1, 2006 | 08:18 AM
  #36
C7LOU's Avatar
C7LOU
If you want CAI the one most often mentioned with no build quality or fitment issues is the Callaway Honker. The downside is that it's $490. I've been watching all these threads for some time now and though the Vararam seems to do what it's advertised to do I'd probably save up and go with the Honker if I decide to change my Blackwing out. Just my $.02!
Old Apr 1, 2006 | 02:03 PM
  #37
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
I run the vararam and am very pleased with it. Great seat of the pants increase,,,I have not measured anything though..
If I were to do it again,I would prolly spend the extra bucks for the Honker.
Mainly because it has excellent gains, but more importantly to me,it is c.a.r.b. rated! Therefore legal in Ca. The vararam is technically not, and I did not know this when I bought it
I still love it though
To Vararam Air Intake
Old Apr 1, 2006 | 02:06 PM
  #38
flynbya2's Avatar
flynbya2
Originally Posted by Threed
I left the lower intake section of the VR and re-installed my Halltech Stinger. The VR brings fresh air up to the Halltech. Certainly not a ram air but great filtering.
Not a bad idea
Old Apr 1, 2006 | 02:34 PM
  #39
NoOne's Avatar
NoOne
Anyone have a link to the install directions?
I am in the middle of putting mine on and the photocopied pics suck.
I have Z06 screens, brake ducts and all they say is REMOVE but I didn't put those parts on and its not very clear how to take them off.
Normally I'd blow through it but all that plastic crap breaks pretty easy so I want to do it the right way.
The quality isn't the greatest and I'm starting to wonder how its going to snap together, but once its together its together and as long as it works.
Old Apr 1, 2006 | 04:15 PM
  #40
chiefDave's Avatar
chiefDave
PIA to install but worth it IMO. Loosk kinda cheesey and if I had to do it again, I would go with a Haltech.
Dave
