[Z06] Vararam Air Intake
Old Mar 3, 2006 | 04:35 AM
HACKSAW's Avatar
HACKSAW
Default Vararam Air Intake
Local Corvette Guru Is Suggesting The Vararam For My 03 - Zo6 - Presently Stock.also Going To Make Some Computer Upgrades.
Feedback Please - Yes 0r No?
Old Mar 3, 2006 | 06:17 AM
balduran's Avatar
balduran
I saw tremendous gains when I installed my Vararam. Went from running a 13.0@108.8mph with a home-ported tb and Corsa to running a 12.79@113mph. Both with 2.1 60ft's, in similar weather conditions.
Old Mar 3, 2006 | 02:42 PM
DPG's Avatar
DPG
St. Jude Donor '06
here comes the debate...its all about what you wanna do. A lot like the performance of the vararam, but hate the quality. My install went pretty smoothly, and im happy with mine. Others will say it was a pain in the *** to install and that its cheap plastic. If you dont mind spending an extra hr or so installing it, then you will be happy with this mod. Goodluck.
Dave
oh and the foam filters suck, so get the k&n for it or that green filter, dont remember the name for it. I'll be changing the filter to a k&n sometime this summer.
Old Mar 3, 2006 | 03:58 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
I noticed a nice improvement with mine as well.
Ron
Old Mar 4, 2006 | 09:10 PM
C6 XPLOSVE's Avatar
C6 XPLOSVE
I went with the Vararam and I love the performance it gave my Vette. Go with it, you will love it!
Old Mar 6, 2006 | 01:26 PM
401K Z06's Avatar
401K Z06
I called Vararam to order a new style "green" filter to replace the foam, and was told that I need to grind or cut off the lip of the lower housing of my VR-1B for the green filter.
DPB: You referenced K&N. Have you got the part #, by chance?
Thanks.
Old Mar 6, 2006 | 03:37 PM
90pololt4's Avatar
90pololt4
I agree with the fit and finish, it takes a little work. I feel a better response above 70mph then before. Has not been on the dyno so I don't know what the real difference is in HP gain.
Old Mar 6, 2006 | 03:42 PM
DPG's Avatar
DPG
St. Jude Donor '06
Sorry, I dont have it off hand. I tried to do a quick search and came up empty. If someone knows it, can you please post it. Thanks.
Old Mar 6, 2006 | 03:53 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Hacksaw -
The VR is probably one of the best performing setups - many swear by them - I have a TRAP on my Z - did not want the VR when I got it and looked at it.
The Vara Ram folks are great with customer service I must add.
Are you going to the strip? Does .1 mean a lot to you in the 1/4 mile?
If not, the good old zip-tie mod is a nice cheap alternative way to open up the intake.
I run a Halltech TRAP on my Z, and a twin ram on my coupe. Happy with both.
best regards -
mqqn
Old Mar 6, 2006 | 06:50 PM
JeremiahsC5's Avatar
JeremiahsC5
Anyone know the part number for the replacement K&N filter and where I can purchase it?
Old Mar 6, 2006 | 07:58 PM
Mikey Z's Avatar
Mikey Z
k+n part # is 33-2522
Old Mar 6, 2006 | 08:14 PM
Kappa's Avatar
Kappa
My friend had a Vararam and he said it felt much stronger up top. So we went to the dyno and it put out about 5whp more than the bone stock dyno. He took it to the local tuner and found that his injectors were running at 100% duty cycle! The Vararam was taking so much air that the computer couldn't adjust. With a tune he went from 358whp to 377whp.
The Vararam by itself does very well but it's even better when it's tuned.
Old Mar 6, 2006 | 08:48 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
IMHO, I think that there is a definite gain from the VR. But I tried all different methods to get it to filter properly but did not prevail. I could always find grit on the throttle body. So I invented the Hall-A-Ram. I left the lower intake section of the VR and re-installed my Halltech Stinger. The VR brings fresh air up to the Halltech. Certainly not a ram air but great filtering.
Old Mar 7, 2006 | 08:11 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Was thinking about adding it to my 04 Z but now I will. Can someone elaborate on the actual installation of the unit? Problems, tricks, tips, do's & dont's????
Thanks,
Bob
Old Mar 7, 2006 | 10:15 AM
DPG's Avatar
DPG
St. Jude Donor '06
Thanks,
Bob
cajundude has a nice write up this install. I used it and my install went pretty smooth
Old Mar 8, 2006 | 12:07 AM
shurite44's Avatar
shurite44
There is no need for fabricating with a vararam install. All parts come with it and it is a direct bolt on.
Old Mar 19, 2006 | 02:46 PM
kinyu's Avatar
kinyu
I noticed most other air intakes come with a replacement air bridge; however the VR does not, judging from the pictures. What is the reason for this? Would you get more HP if you put a different air bridge in?
To Vararam Air Intake
Old Mar 20, 2006 | 05:06 PM
63Corvette's Avatar
63Corvette
I had my VaraRam VR-2B installed by M&T Automotive in Mont Belvieu, Texas (281/576-5100). They did a great job, and did it quickly. If anyone in the Houston area needs help with the install, please give me (or Ted Filer at M&T) a call, and I'll discuss the details.
Old Mar 20, 2006 | 07:57 PM
slong's Avatar
slong
Ron
Old Mar 22, 2006 | 06:21 PM
glind46677's Avatar
glind46677
I added VR to my 04 but nothing made the difference the 343 gear with the TC made.
