throttle body with fast intake?
Old Mar 4, 2006 | 10:43 AM
rxwinters's Avatar
rxwinters
7th Gear
Default throttle body with fast intake?
does anyone know if an ls2 throttle body would work with a c5 car or would any adjustments be needed. also what are some of the throttle bodies which can be used for the 90mm fast intake on a c5
Old Mar 4, 2006 | 11:30 AM
2ndVette's Avatar
2ndVette
the LS2 TB will work on a C5 with some wiring conversions(and accepting intake). You will need either the pigtail piece or the newer, true plug 'n play adapter that has 3 connectors in place. The FAST intake works with LS2 TB, the TPIS 90 and the NW unit. I don't know for sure if the FAST 90 TB ever made it to prime time.
