Soundproofing
Old Mar 6, 2006 | 02:04 PM
2k1 VET's Avatar
2k1 VET
Default Soundproofing
I have a question?
I have a 2001 Corvette with run flats which are very noisy. I really am disappointed that the factory did not do a better job of soundproofing that car. I understand that the idea was to save weight, but I don't think that soundproofing would increase the weight very much.
I am considering having it soundproofed. The cost would be approximately $1500 which does not bother me.
My question is this. Is it worth going to the extra expense if most of the noise emanates through the glass.
I would appreciate some feedback.
Old Mar 6, 2006 | 02:08 PM
wit2pz's Avatar
wit2pz
Plenty of 'diy' threads on soundproofing the Vettes. I want to do this mod myself, and the consensus from the diy threads have been "Glad I did it, but THANK GOD ITS OVER!!! WHAT A PITA!!!"
I think the results are worthwhile, from what I've seen. Also, consider a different brand/model tire. The stock tires are notoriously loud, from all I've learned here.
Old Mar 6, 2006 | 02:18 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
Originally Posted by 2k1 VET
I have a question?
What does that $1500 get you? Here's an alternative that gets great reviews for about 1/6 the price:
http://forums.corvetteforum.com/show...on&forum_id=53
Old Mar 6, 2006 | 02:22 PM
fdxpilot's Avatar
fdxpilot
I have a question?
I don't know where you got that price info from, unless you're paying people $100 an hour to do it. I got the insulation kit from exotic vette for a little over $200 and put a couple afternoons in over the weekend. Reduced, but didn't entirely eliminate the sound. Next step is to insulate behind the rear wheel liner. That is supposed to do the most for tire noise.
Old Mar 6, 2006 | 02:23 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
GM is in a catch 22 here you want soundproofing while others want weight reduction. So GM went with weight reduction. If you use product like Dynamat it will weight but not sure how much.First of all get rid of the runflats which get noiser as they get older and got with a tire like GY Eagle F1 GS-D3 which are quiter.
Old Mar 6, 2006 | 02:24 PM
JTS97Z28's Avatar
JTS97Z28
Im curious as well what exactly will you be getting done for $1500? I do agree the Corvette could have been made to be a little more quiet. I added the pre-cut insulation kit to my vette and I must say it was hard to notice a difference in sound however it is true that the center console does not get nearly as hot anymore.
I am curious though what do other cars of this kind sound like inside? Ferrari 360, Porsche etc etc? I have never been in one to compare noise levels.
Old Mar 6, 2006 | 02:42 PM
danberry's Avatar
danberry
I agree with the fellow members($1500) you got to be kidding.......I did the Frost King material....even though I doubled the thickness it is still hard to tell a 5-10 dec. drop a that noise level.....in other words ..don't expect miracles.........
Old Mar 6, 2006 | 03:22 PM
BATM4N's Avatar
BATM4N
I just talked to Dan at sales@exoticvette.com He sounds like a straight up guy I'm going to order this insulation kit both front and back and let you know how it goes. Doesn't sound difficult at all, rather just time consuming (about a t whole day)
Old Mar 6, 2006 | 03:42 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Gotta have two cars. A sportscar for rumbling around in without regard to the sound, and a chi-chi upscale performance sedan for the smooth, quiet ride.
I've thought about adding sound insulation to my vert, but will try quieter tires first. When I really want to reduce the noise, I'll drive the Jag.
Old Mar 6, 2006 | 06:55 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It cost me about $1,500 to insulate my vette coupe with "koolmat"
Here's a link to the install by Vette Magazine http://www.vetteweb.com/tech/vet_0504_sound/
The stuff works well but is PIA to install. You have to spray a lot of glue down and let it get tacky before you can position in place. Took me two weekends to complete the job including removing and re-installing the interior.
Old Mar 6, 2006 | 08:28 PM
Jake T's Avatar
Jake T
Just finished mine last week. Did the complete interior and the wheel wells. Cost me a total of $50....
Old Mar 6, 2006 | 08:31 PM
iteachflyin's Avatar
iteachflyin
Drop your pressures to 28 and the tires will quiet down and reach 30-32 at cruising speeds. At 34-35 and above the tires are unbearably noisy.
Old Mar 6, 2006 | 08:38 PM
DBFCO2's Avatar
DBFCO2
Default $50.00
What did you use only 50.00 dollars resaults???
Old Mar 8, 2006 | 07:25 PM
2k1 VET's Avatar
2k1 VET
Thank you for the info.I think I will start by getting rid of the run flats.This should make quite a difference
Old Mar 8, 2006 | 08:03 PM
scott_fx's Avatar
scott_fx
but frost king is hardly sound deadening material. I know a lot of people use it but it's not what it's engineered for.
Old Mar 8, 2006 | 09:30 PM
JEEP/C5's Avatar
JEEP/C5
Frost King works well, Its cheap, relatively easy to use, self sticking, reduces interior temps, fairly light weight and you can by it at almost any hardware store in town. It’s a great product for mild insulating interiors and if you do most of the large areas in back in front you can tell a difference. It’s a worthwhile mod IMO.
Old Mar 8, 2006 | 09:42 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
To Soundproofing
Old Mar 8, 2006 | 09:49 PM
tiojames's Avatar
tiojames
Default insulation
One thing I found that really helped is a post I read a while back about doing the inner rear wheel panels. I did the whole inside of my car and was a little disappointed in the lack of sound reduction. Took off the inner rear panels and did them- made a noticeble difference. Bigger difference was to get rid of the runflats.
Old Mar 8, 2006 | 10:32 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I have a question?
For $1500, I'll jump on a plane and do it for you.
Serious.
http://forums.corvetteforum.com/show..._id=103&arch=1
Old Mar 8, 2006 | 10:59 PM
rcs128's Avatar
rcs128
I bet he IS serious...
