[Z06] Dealer service question.
Old Mar 6, 2006 | 08:43 PM
Bret01Z06's Avatar
Bret01Z06
Default Dealer service question.
I'm getting a 2001 Z06 and had the vin run by a dealer. This is what I was given. Most of it makes no sense to me.
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
05/24/2005 287160 # V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 43843 miles
04/02/2004 520495 # J6090 - VALVE, SAI CHECK - RIGHT - REPLACE 35911 miles
04/02/2004 520495 # C6041 - ADJUSTER ASSEMBLY, FRONT SEAT POWER - BUCKET SEAT - DRIVER 35911 miles
04/02/2004 520495 # E4300 - BEARING AND HUB ASSEMBLY, REAR WHEEL - RIGHT - REPLACE 35911 miles
04/02/2004 520495 # N4010 - LIGHTER ASSEMBLY, CIGARETTE - REPLACE 35911 miles
12/11/2003 514691 # N4800 - MODULE, COMPUTER (CONTROL) BODY - REPLACE 31393 miles
12/11/2003 514691 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 31393 miles
09/13/2003 513634 # J0667 - BELT, PRIMARY ACCESSORY DRIVE - REPLACE 24722 miles
09/13/2003 513634 # N4920 - MODULE, LOCAL INTERFACE UNIT - DOOR - RIGHT - REPLACE 24722 miles
09/02/2003 511889 # H2410 - SENSOR, WHEEL SPEED - FRONT - RIGHT - REPLACE 24213 miles
09/02/2003 511889 # Z7901 - 1-DAY COURTESY TRANSPORTATION 24213 miles
01/13/2003 182493 # Z8014 - ROADSIDE SERVICE (BATTERY/JUMP START) 16925 miles
01/09/2003 688843 # N0110 - BATTERY - ONE - REPLACE 16929 miles
01/09/2003 688843 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 16929 miles
07/22/2002 671252 # J0900 - CAP, OIL FILLER - REPLACE 11881 miles
03/11/2002 656656 # J0251 - GASKET, INTAKE MANIFOLD - REPLACE 8289 miles
11/20/2001 645096 # T2020 - TOWING 5596 miles
10/24/2001 641842 # J1307 - PISTON, ROD AND/OR RINGS - ONE CYL - BOTH BANKS - REPLACE 4750 miles
10/24/2001 641842 # Z7902 - 2-DAY COURTESY TRANSPORTATION 4750 miles
04/25/2001 A29175 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
The one I'm wondering about it the ring one. Looks like them ment to put "on cyl-Both Banks". Sounds like the car might have been reringed.
Please help this newbie.
Thanks,
Bret
Old Mar 7, 2006 | 11:38 AM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
I would agree. It looks like it got rings in it. the owner was probably one of those people who thought that the piston slap noise is not normal. He probably cried about it and got the car re-ringed to make him feel better.
Old Mar 7, 2006 | 11:42 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Care has been re-ringed and the valley seal has been chaged out... this is great news. I wouldn't buy an '01 w/o it unless I was ripping the engine out anyway.
Mine's oil burn free after re-ring.
Old Mar 7, 2006 | 11:29 PM
Bret01Z06's Avatar
Bret01Z06
Thanks for the help guys. I remember the computer throwing a LDCM and RDCM code. I need to check those out.
Old Mar 31, 2006 | 10:04 PM
zozmanZ06's Avatar
zozmanZ06
Default Steering Column Lock Service
From Car History printout:
05/24/2005 287160 # V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 43843 miles.
This means the column lock service campaign was completed.
Randy
Old Apr 1, 2006 | 07:46 PM
Bret01Z06's Avatar
Bret01Z06
Randy
Yeah I found that out when I got the car. One less thing I have to worry about.
To Dealer service question.
