Service ABS and Active Handling
Old Mar 8, 2006 | 07:06 AM
DeeGee's Avatar
DeeGee
Default Service ABS and Active Handling
I was idling in traffic today and the ABS and AH tripped out with associated captions. First time its ever happened and it recycled after shutting off the car and restarting.
From previous posts it seems to be due to a temporary voltage drop. Makes sense as I'd sat in traffic at the off ramp for 5 minutes.
I saw Bill Curlees post on the corroded connector and wheel hub sensors. That's not likely to be an issue in Vegas as the climate is dry. My battery is good.
How common is this? Anyone else have this occasionally?
Old Mar 8, 2006 | 10:28 AM
rjbigdog's Avatar
rjbigdog
I had the same thing happen to me about 3 months ago. It happened and rest twice about a week apart. The 3rd time it happened it never reset. After checking all grounds and connectors I ended up replacing the EBTCM. I hope this is not your problem because of price unless you still have coverage. Then it might be the best because the other options are sometimes hard to troubleshoot. Start by checking to see if you have any codes still in history. Mine was C1214. If it turns out to be a wheel speed sensor code then check the connectors and grounds per Bill's post.
I hope it was a one time fluke and all is well. Good luck!
Tony
Old Mar 8, 2006 | 10:37 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Tony
that pretty much sums it up...I had the same thing, same code (s) C1214 etc... ended up being the EBTCM or EBMV which was a 2800 repair thank god I was still under OEM warranty
Old Mar 8, 2006 | 10:56 AM
rjbigdog's Avatar
rjbigdog
To share a little more info. I got the EBTCM from gmpartsdirect for less than $700 shipped. I consider this a DIY part for just about anyone comfortable changing their own oil. 6 screws and 2 electrical connectors. Takes about 30 minutes to change.
Old Mar 8, 2006 | 11:20 AM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
Wow nice find! Hope it is not that bad of an issue. Any H codes? Good luck!
Dave
Old Mar 8, 2006 | 07:23 PM
DeeGee's Avatar
DeeGee
Thanks for the posts guys.
If it could be as bad as the EBTCM I'll keep a very close eye on it.
My GM warranty has expired but I have GMPP. problem is I go back to England at the end of the year and cover doesn't extend to UK. If this is a problem I need to get it fixed before I leave.
Old Mar 8, 2006 | 07:47 PM
artfahie's Avatar
artfahie
I cleaned my connections today & then drove about 40 miles without the ABS lighting up... it normally wouldn't go but about a mile or two without being triggered. You might want to consider & cleaning before spending alot of money. Good luck.
Old Mar 9, 2006 | 08:17 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Mine did that months ago , and has not come back .
the problem was the brake fluid was low . apparently that triggers these lights to come on .
good luck
Old Mar 9, 2006 | 08:29 AM
hardtop's Avatar
hardtop
This worked for me. Lots cheaper to try this first. Even dry climates can produce corrosion, ever so slightly, and thats all it takes.
ORANGEBROTHERS's Avatar
ORANGEBROTHERS
Sorry to say same thing happend to me. Eventually had to replace the electronic brake control (EBCM) $1200.00 parts and labor. Hope you still have a warranty.
Old Mar 9, 2006 | 08:31 AM
ORANGEBROTHERS
I did the same thing, worked for a while but had to eventually replace the EBCM.
Old Mar 9, 2006 | 09:52 AM
DeeGee's Avatar
DeeGee
Just checked my codes and I have a history C1214.
I'll watch it for a while but I think I may be dusting off my GMPP Warranty
Old Mar 9, 2006 | 02:03 PM
C502's Avatar
C502
Which connector's or connection's did you clean?
Old Mar 9, 2006 | 02:10 PM
C502's Avatar
C502
Old Mar 9, 2006 | 02:28 PM
YBNORML's Avatar
YBNORML
good luck
Same here, a little brake fluid fixed the problem!
Old Mar 9, 2006 | 05:57 PM
JUST1BAD92VETTE's Avatar
JUST1BAD92VETTE
hey guys,
may i get in on this ......my abs/asr unit in the rear compartment on my 92 LT1 keeps humming/running with the car off......the battery is the only thing that will stop it(DISCONNECT)everything was fine.battery went bad ,replaced it,now this happens?any help would be appreciated.
To Service ABS and Active Handling
