Lowering Question, Help!
Old Mar 9, 2006 | 01:59 PM
PashaCorvette's Avatar
PashaCorvette
Default Lowering Question, Help!
I have a question on the lowering bolts,, On my front bolts, when I went to lower the car,, I realized that there arn't any washers for the bolts.. Is this a problem?,, Are they supposed to be there but they fell off? I already did the back, which had the washers, and I am worried that the front ones fell off or I lowered it too much,, any solutions would be greatly appreciated!! Thanks.... Pashacorvette
Old Mar 9, 2006 | 02:01 PM
DPG's Avatar
DPG
St. Jude Donor '06
the fronts dont have washers, when you are turning the front bolts, you are turning the whole bushing at the same time. dont worry, lower away. you have to remember with the fronts, is that, you want more thread exposed. This brings the bushings closer to the spring.
Old Mar 9, 2006 | 02:12 PM
PashaCorvette
Default thanks so much!!
Whoo,, thanks alot for the info,, I was a little worried as Im not much of a mechanic but Im always learning!! Good to know
have a great day! Pashacorvette
Old Mar 9, 2006 | 03:15 PM
DPG's Avatar
DPG
St. Jude Donor '06
no prob, the tech section has a pretty good write up and lower away
heres a copy/paste from the tech section:
Front:
1. Make sure the car is in gear to prevent it from rolling.
2. Raise the car with the jack positioned in the center of the front cross member.
3. Place the two jack stands under the cross member, and SLOWLY lower the car onto them.
4. Remove the front wheels. It may be necessary to slightly loosen the lug nuts before the wheels are completely off the ground.
5. Find the front leaf spring, and with a 10mm wrench or socket, turn the bolt as if you were loosening it (It is reverse threaded so you are actually tightening it).
6. Turn the bolt until there is no longer a gap between the bushing and the bolt. Measure the exposed threads to insure the other side is done the same.
7. Put the wheels back on and lower the car. NOTE- It may be necessary to place a board under the tires so you will be able to remove the floor jack once the car is lowered.
Old Mar 9, 2006 | 03:22 PM
BAD_TCR's Avatar
BAD_TCR
Remember too, even if they did "fall out" (which is impossible since you are actually screwing them in further to lower, and the fact that the a-arm would keep them in ) you can run around with no bolts in the front and be perfectly fine.
Old Mar 9, 2006 | 06:45 PM
MrLeadFoot's Avatar
MrLeadFoot
Wait, I thought the front bushing itself was NOT supposed to turn with the bolt. Mine turn with the bolt and it makes it damned hard to turn, even with a jack under the spring, and especially when raising the car to find that sweet spot. Am I wrong in assuming my bolts are seized in my bushings? I mean, I've heard of people saying they turn their fronts by hand, but if the bushing turns with the bolt, how can that easy of a turn be possible?
Old Mar 15, 2006 | 03:28 PM
Goldenboy's Avatar
Goldenboy
Are you implying that for the rears, you want less thread exposed?
Old Mar 15, 2006 | 03:46 PM
MrLeadFoot's Avatar
MrLeadFoot
Yes. Less threads exposed when viewing the bolts from the top of the springs.
UniqueDoug's Avatar
UniqueDoug
I've done about 11 vettes in the good ole days, so hopefully will be able to address this...the bushing on the front and bolt are one piece. I've done a few where to get the extra slam that bolt is removed all the way and the bushing is cut off, leaving just the bolt and flat head. With the lower A loose (I always took that whole assembly apart) and a jack under the leaf (use pads) to take pressure off the spring (as you noted), they screw right up. If it is hard then it is just a virgin bolt perhaps??? I believe it is a 10 mm???
Old Mar 15, 2006 | 05:42 PM
MrLeadFoot's Avatar
MrLeadFoot
Thanks for the clarification on the bolt and bushing being one piece.
Old Mar 15, 2006 | 05:45 PM
steveblonde's Avatar
steveblonde
the million dollar question i have is
if you lower on the stock bolts do you still need an allignment - one post i read says no - others say yes
Old Mar 15, 2006 | 08:31 PM
bcseitz's Avatar
bcseitz
Here are a pair of brand new front bolts with the rubber heads. They came with my new Z06 springs. Hope this helps.
I used my original bolts as I cut the rubber heads off. My ride height is just where I want it.
Old Mar 15, 2006 | 08:49 PM
MrLeadFoot's Avatar
MrLeadFoot
Thanks for the pics! Not that I ever wanted to cut my bushings, but now I know that it must suck if you ever wanted to get those bolts out of the spring. Also, now I know why it's so darned hard to turn those bolts, cause of the friction of the bushing against the lower control arm, even if you jack the spring.
Makes me wonder how people are turning those bolts by hand. They must have really soft springs or something. Maybe some C5s come with the 200 lbs rated ABC1 springs or something!
Old Mar 15, 2006 | 09:01 PM
edensknight's Avatar
edensknight
BC, that is a great pic of your beautiful white C5. Love that Arizona landscape! Thanks for sharing!
Old Mar 15, 2006 | 09:11 PM
PashaCorvette
Thnks for all the info guys.Sure they helped a lot.
Old Mar 15, 2006 | 09:25 PM
bcseitz's Avatar
bcseitz
Once the car is on stands, you put a couple of pucks on your jack and jack up the end of the spring a little bit till the rubber head of the bolt lifts off the lower control arm.
Once I did that I could turn the bolt with my fingers!
I know some of you guys out there have bolts frozen into the spring and it can be a problem.
LS1howto.com has instructions on how to remove the spring (it's pretty easy). Then put a visegrips pliars and a 6pt. 10mm to that bolt and it WILL come out!
It scared me at the thought of doing this myself but with the great instructions out there (thanks to all the forum members!) it makes the job easy.
Old Mar 15, 2006 | 09:39 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Yes you will...
Peace
Willfulone
Old Mar 15, 2006 | 11:02 PM
sffiredude's Avatar
sffiredude
bcseitz, sounds you may be the local pro I will have to stop by the next time you have the tools out..............
To Lowering Question, Help!
