10 % ethanol
Jake T.
Jake T.
Jake T.
With a 10% ethanol blend, your mileage will suffer slightly. The good news is that with a 10% blend, your horsepower will improve slightly.
As the blend percentage increases, so does the mileage decrease and the power increase. Oh, and your emission levels - all of them, go down.
Tests using E85, an 85% ethanol blend show between 5 and 10 percent decrease in gas mileage, yet show about the same in horsepower/torque increases. These tests were done on cars that were not tuned according to their fuel. So if you were able to tune your car to the higher octane, your power ouput should increase even more so.
Now here the caveat to the 10% blends - not all, but some, such as the 5% blends here in Oregon. Oregon mandated an ethanol blend to reduce the emission levels. Sounds good right? Well, what we ended up getting was a low grade gasoline - so low that it couldn't be sold on its own. However, with the ethanol blended into it, the octane was raised to 87, so it could be sold. The bottom line is, the gas was and is, ultimate crap. It dirties the engine, the oil and the filters and makes the car run horribly. I am not exaggerating.
As a result, ethanol get a bad name here in Oregon and it is too bad because it wasn't the ethanol that was the problem, it was the gasoline that they were putting it into that was the problem. There has been a fairly strong public resistance to ethanol here because of it.
All in all, it was another win for the oil companies. They didn't want ethanol to begin with and fought it tooth and nail. Then when they were finally forced into blending it, they used the worst gas they could come up with, thus making the ethanol look bad. Give the average Oregonian a choice between ethanol and gas, and they'll pick the gas. Big oil won.
Currently, there is a political effort, albeit small at this point, to redefine the blend standard, making the blended fuel better grade.
Anyway, my understanding is you get lower gas mileage in autos and over time it destroys the fiberglass in the fuel tanks of boats. Not good stuff.
Fred
http://www.newton.dep.anl.gov/askasc.../chem99527.htm
