remove key fob battery
Old Mar 10, 2006 | 01:12 PM
white top's Avatar
white top
Default remove key fob battery
OK opened up my key fob `00 battery is on one side circuit board on the other side. the battery is held by what looks like 4 or 5 little plastic tabs. I am concerned that if just pry the battery out I will break the tabs any trick or advice appreciated before I break those suckers off.
Jerry
Old Mar 10, 2006 | 01:43 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Jerry
Hi Jerry -
The battery should pop out - push a couple of the tabs outward and then encourage the battery out that side.
I have a page posted on the following link, but your question brought up a glaring omission - there is no view of the battery side of the passive kind of fob.....I'll correct that in the near future.
http://www.iammoon.com/c5tech/fobs/index.html
best regards -
mqqn
Old Mar 10, 2006 | 03:16 PM
white top's Avatar
white top
Originally Posted by mqqn
Hi Jerry -
best regards -
mqqn
Thanks for the reply but `00 fob is not the passive type hope your info still applies.
Jerry
Old Mar 10, 2006 | 04:19 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Jerry
Hi Jerry -
i'll let you decide - I think yours is the "transitional" year - not stating fact here, I have no 2000 fob to compare to - but I think the 2000 fob was a "fatty", like the previous passive style fog, and then on 2001 they went to the skiny fob that the newer cars all had.
I would be guessing, but if you look at the pics I have on my site, I anm thinking your fob looks like the passive style, but does not have the passive switch.
best regards -
mqqn
Old Mar 10, 2006 | 04:44 PM
jman1's Avatar
jman1
i just replaced mine..... pry one one side and it'll pop right out
Old Mar 10, 2006 | 05:56 PM
Battery should pop out pretty easily once you get the fob open. And yes, the fob itself is rather thick for the '00 cars.
Old Mar 11, 2006 | 11:10 AM
white top's Avatar
white top
thanks for the replies and yes the `00 fob is the fat/ thick one and the battery is held in place differently than the one mqqn showed in his post.
Jerry
To remove key fob battery
