Passenger Side Mirror
Old Mar 10, 2006 | 04:33 PM
mkleisch's Avatar
mkleisch
Default Passenger Side Mirror
I am in the middle of replacing my passenger side mirror. I got the door pannel off and now I am trying to figure out how to get at the wiring. Any suggestions??
I figured it out:
Speaker hole is the answer!
Old Mar 10, 2006 | 04:44 PM
HummelS's Avatar
HummelS
According to the shop manual, you need to remove the speaker assembly & diconnect the connector. There are two mirror nut access plugs that need to be removed. Disconnect mirror electrical connections, disconnect the mirror harness from the retainers, remove nuts from mirror studs. Then remove the mirror with harness and gasket.
