Anyone use Dex-Cool Premixed?
Old Mar 11, 2006 | 12:24 AM
John's '07's Avatar
John's '07
From: I don't deserve this car, but I have arthritis and I don't deserve that either. Bay Point, FL
St. Jude Donor '06-'07
Default Anyone use Dex-Cool Premixed?
The General sez to mix Dex-Cool 50/50 with drinking water. This stuff is premixed and I assume it's okay use. Before I add a little, are there any problems with it? Thanks.
Old Mar 11, 2006 | 07:37 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Just make sure the water they use is distilled or filtered. If not, you might have a rust issue later on.
Old Mar 11, 2006 | 07:39 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
used it..no problem..much easier than mix it yourself....you know the mixture is
Old Mar 11, 2006 | 11:58 AM
Mike04's Avatar
Mike04
Old Mar 11, 2006 | 01:29 PM
binkysgarage's Avatar
binkysgarage
The 50-50 mix isn't much cheaper than the 100% mix, for the money I can take the little time it takes to mix.
Old Mar 11, 2006 | 01:38 PM
sage666's Avatar
sage666
nope, always use distilled water to mix.
Old Mar 11, 2006 | 02:41 PM
c4cruiser's Avatar
c4cruiser
It's funny that the Dex-Cool can be mixed with drinking water but most brands of the green (ethlyene glycol) coolant recommend using distilled water.
The service manual procedure for refilling after a flush and complete drain simply says to add 2 gallons of coolant followed by the balance of the amount as just water. The water pump will do the mixing for you
You can buy distilled water at most grocery stores for around a buck a gallon so it's cheap and easy to mix your own. Once you fill the system, you still have to add the mix to the overflow tank and it's always a good idea to keep a pre-mixed gallon of coolant in the garage.
Old Mar 11, 2006 | 11:06 PM
John's '07's Avatar
John's '07
Thanks for the input. I followed the manual's instructions, added the required Cool-Dex 50/50 premix, and the engine seems to be running cooler. The level was down about half an inch from the full cold level. Thanks again! John
To Anyone use Dex-Cool Premixed?
