Do I Have Minor or Major Problem ?
Today while driving (2000 Coupe) my headlights popped up and I never touched the headlight switch. I started to turn the headlights on and off to try and retracked them but they stayed up...when I finally pulled over and turned the car off, then they reset themselves back down. But once I started the car again, they popped back up...what's going on here? Is it something that I can re-set with the computer myself or do I need to bring it to the drealer for maybe a new motor to run them properly?
Thank you for any advice you can give.
Don't feel bad, I did the same thing when I first got my 04 vert. Twilight sensor set to OFF did the trick.
From the Manual:
Twilight Sentinel Automatic Lamp
Control (Optional in United States,
Standard in Canada)
Twilight Sentinel can turn your lamps on and off for you.
A light sensor on top of the instrument panel makes the
Twilight Sentinel work, so be sure it isn’t covered.
You can customize your vehicle to turn Twilight
Sentinel on or off (except for vehicles first sold in
Canada). See “Driver Information Center (DIC)” in
the Index to turn this feature on or off.
When Twilight Sentinel is turned on, you will see the
following happen:
When it’s dark enough outside, the front turn signal
lamps (DRL) will go off, and the headlamps and
parking lamps will come on. The other lamps that
come on with headlamps will also come on.
When it’s bright enough outside, the headlamps
will go off, and the front turn signal lamps (DRL)
will come on, as long as the exterior lamp switch is
in the OFF position.
With Twilight Sentinel turned on, you can idle the
vehicle with the lamps off, even when it’s dark outside.
First set the parking brake while the ignition is in OFF.
Then start the vehicle. The lamps will stay off until you
release the parking brake.
Twilight Sentinel also provides exterior illumination as
you leave the vehicle. If Twilight Sentinel has turned on
the lamps when you turn off the ignition, your lamps
will remain on until:
The exterior lamp switch is moved from OFF to
the parking lamp position, or
a delay time that you select has elapsed.
See “Driver Information Center (DIC)” in the Index to
select the delay time that you want. You can also select
no delay time.
If you turn off the ignition with the exterior lamp switch
in the parking lamp or headlamp position, the Twilight
Sentinel delay will not occur. The lamps will turn off as
soon as the switch is turned off.
As with any vehicle, you should turn on the regular
headlamp system when you need it.
http://www.trademotion.com/splash/in...?siteid=214152
Besides...then you can control your lights better...parking and fog lights at dusk looks awesome.
