Taillight seals seem to be the newest rage.
I had some grey Frost King weatherstrip in the basement and thought I would see if it would work.
Basically cut to length, apply to an alcohol cleaned lens edge. Pre- clean and spray the taillight cut out with a detailer to provide a bit of lubricity. Using two torx drivers ( pushed through the screw holes) wiggle the weatherstipped lens into place.... cost about $2.65 from Lowes
