Replacing Brake Light Bulb
Old Mar 13, 2006 | 09:39 AM
VETSTYL's Avatar
VETSTYL
Default Replacing Brake Light Bulb
Right rear brake light on 00 Vert does not work. All other lights work. Thought a simple replacement situation. On cars in my past, I would just remove the carpeting against the wall and would have access to all of the lights. You can imagin my horror when I removed the carpeting and all I saw as a metal wall.
I have blackout covers over my lenses.
Do you gain access to the bulbs through the lense cover?
VETSTYL (Riding the Veteran Style)
27 Year Army Vet
Old Mar 13, 2006 | 09:42 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Just remove the two screws that you see on the outside of the lense. The whole assembly will come out and the bulb is accessible that way.
Old Mar 13, 2006 | 09:50 AM
rws.1's Avatar
rws.1
with BlackSedan87....
Just had my lenses off to install taillight seals.
Two "torx head" screws . pull out the housing and the bulb is accessed by removing the socket from the back of the housing.
Old Mar 13, 2006 | 12:00 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
That should have you covered.
Old Mar 13, 2006 | 12:29 PM
Vette Nutz's Avatar
Vette Nutz
Replacing the tail light bulbs on a C-5 is much easier than changing them on a C-4. It is major surgery to replace the outboard tail light bulbs on a C-4.
To Replacing Brake Light Bulb
