[Z06] DOT Drag Radials
Old Mar 13, 2006 | 04:46 PM
ROADTRIPR's Avatar
ROADTRIPR
Default DOT Drag Radials
Am interested in putting a set of Street Drag Radials on my '02 Z06, could use some info and suggestions. Have done a little research on Nitto's and BF Goodrich T/A's. Currently have F1's(295/35-18's) can't find a match in the Nitto's but did find the same size in the T/A's.
Old Mar 13, 2006 | 05:04 PM
Rick@CTCORVETTE's Avatar
0Rick@CTCORVETTE
Former Vendor
The same thing happened to me. I haven't bought either one yet but.. most say go with the BFG's. More info on this topic is needed
Old Mar 13, 2006 | 05:45 PM
02bpdz06's Avatar
02bpdz06
Well i've done some research on the forum as well as had some real world experience. The bfg's hook alot better, but aren't for every day driving. The sidewall's are softer than the nitto's and the car not only sways at higher speeds, but also loses alot of its cornering. The nitto's hook well, are z rated, with a stiffer sidewall. I had a s/c 98 cobra with the nitto's and loved them. I'm gonna be ordering a set of nitto's this week for my soon to be blown z.
Chris
Old Mar 13, 2006 | 11:37 PM
petercln's Avatar
petercln
I just got a set of Nittos 305 18s they work well enought for me going around corners. I just got back from a Corvette forum run to Laughlin and i kept up well enought in the corners the active handeling never came on once. They seem to do great in the light rain we have been getting here in So Calif. This Thursday night I well be at the local 1/8 mile track and can let you know how well they hook.
Old Mar 14, 2006 | 06:18 PM
0Rick@CTCORVETTE
Former Vendor
I'll try the Nittos first. I don't want to swap the rubber (rims) every time I go to the track.. which isn't that often. Maybe 3 times this year.
Old Mar 14, 2006 | 06:36 PM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
The Nitto Drag Radials are the best hands down if you plan to use them for any kind of normal commuting, they are a full tread depth tire, provide good rain traction, wear well and hook great. I believe the BFG's are stickier and will likely net you a better 60' but they wear very quickly and god forbid you get caught in the rain once they wear a bit.....good luck. You will give up a bit in the handling department compared to the GY SC's. If you dont want to give up handling and are will to compromise a bit of straight line traction for better handling then you may want to look at the Nitto RII's they are the same tread pattern but less tread depth, they have a stiffer sidewall than the Drag Radials but use a soft compound just the same.
Old Mar 15, 2006 | 11:45 AM
ROADTRIPR's Avatar
ROADTRIPR
Thanks for the info, it looks like a set of Nitto 305 18's are what I am looking for, I do quite a bit of country running and some rolling runs. I assume the Nitto's will fit my present rims with no problems. Time to get some $$$$. Thanks again..
Old Mar 15, 2006 | 12:17 PM
rutiger's Avatar
rutiger
i have run nitto Rs, R2s, and now BFGs. my opinion is all three are pretty useless in the rain. nittos are ok when they're new, but once you start wearing them down they're terrible in the rain. on my way to LA i got caught in the rain with the R2s and i had to slow down to ~30 on the freeway and it was still trying to go sideways on me. i was about to just pull off and get a hotel, but then the rain let up. i bought an extra set of rear wheels to mount the BFGs so i can swap them on and off at will.
after running all three of these tires my choice is for the BFGs. they're the best at what they're intended for which is a drag tire.
Old Mar 15, 2006 | 01:42 PM
Richie Carbone's Avatar
Richie Carbone
Have you thought about the MT ET drag radials?
I just put a set of MT 275 40 17's on the rear mounted on chrome 17X9.5 ZO6 rims.
They drive great on the street, even with them aired up to 29 lbs I can't spin them on the street. If I dump the clutch at 2000 RPM they only chirp once and then it's like being launched out of a sling shot.
I'm heading to the track tonight, I'll post my results.
Old Mar 15, 2006 | 02:17 PM
ROADTRIPR's Avatar
ROADTRIPR
Forgive my ignorance but who makes MT drag radials? I have priced the Nitto 555R and they are just a little tooooo high for me, $800+ for 2. I was hoping to find something in the $220/250 range(2), i could be dreaming..
Old Mar 15, 2006 | 02:24 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Just got a set of 555's in a 305. Just step up to the 305 and it won't change a thing. The difference in diameter is only like 1/10 of an inch. These things hook
Old Mar 15, 2006 | 02:59 PM
ROADTRIPR's Avatar
ROADTRIPR
Are these the NT555R's? If so, the cost here is $320 a pop, just too steep for me.
Old Mar 15, 2006 | 03:14 PM
bernrex's Avatar
bernrex
The Nitto 555ZR's are the true street tire. For those that only occasionally go to the track, and drive in the rain. Also wear better than the others. I think I gave 200 a tire last year on set of 4.
Old Mar 15, 2006 | 03:38 PM
Richie Carbone
MT= Mickey Thompson.
The rims cost $249.99 X2 +shipping from Corvette Garage
The Drag Radials were $160.99 X2
So for about $900.00 you could have a great strip set up.
Old Mar 24, 2006 | 10:33 AM
BobA's Avatar
BobA
Chris
I've been using BFGs 315x30s I can get 1.64 60' time and 11.80@118MPH on them,BUT I agree that they wear fast, so I have 2 extra wheels with them mounted for racing. I took them too 140mph too see if they got too wild but no problem in a strait line. My car is stock, just the DRs. I run at Capital in Md, alt about 300' baro about 30.00 I've run at MIR,Cecil,English Town,Atco and others, run about the same at all tracks.
BobA (Now in Mo.)
Old Mar 24, 2006 | 10:57 AM
Ranger's Avatar
Ranger
They drive great on the street, even with them aired up to 29 lbs I can't spin them on the street. If I dump the clutch at 2000 RPM they only chirp once and then it's like being launched out of a sling shot....
Risk tolerance is for each owner to decide.
But, while MT ET Street Radials are great at the drag strip, they are, to me, a very risky street tire. They are
(1) treacherous on wet streets
(2) so soft of compound that they track every nuance of the road, meaning they NEVER settle down, and
(3) unstable on turn and off-ramp (at 35 they set off active handling on off-ramps I normally take at 58 with BFG DRs).
I drove to and from the track with the MT radials mounted but was always extremely cautious.
In contrast I put about 8K miles on a pair of BFG 315.35.17s when I was racing nearly every weekend in the fall of 2002. Very stable and predictable behavior at speeds to 160. Off-ramp speeds not that far off F1SCs. But gotta be very careful with them on wet streets.
Ranger
Old Mar 24, 2006 | 11:04 AM
BobA's Avatar
BobA
Ranger
I'm with you
BobA
To DOT Drag Radials
Old Mar 24, 2006 | 11:37 PM
KyleBst264's Avatar
KyleBst264
My Mickey Thompson DR's are on the way. I will be mounting them on chrome Z06 front wheels which I'm also waiting for.
Old Mar 25, 2006 | 10:27 AM
JeremiahsC5's Avatar
JeremiahsC5
I went with Mickey Thompsons 275 40 17's on the rear mounted on my stock front 17X9.5 ZO6 rims. They are great for the track but I only run them to and from the drag strip. If you want sticky there the way to go. If you want a good daily driver street radial I would go with the BFGs.
Old Mar 25, 2006 | 01:20 PM
Dantas's Avatar
Dantas
St. Jude Donor '06
Aye, MT drag radials are super sticky but I wouldn't suggest driving daily with them. Get a good set of street tires that corner well and just get another 2 rims with the drag radials mounted on for when your headed to the track. They will drive just fine to and from the track and that is what they were meant for anyway.
That way you don't tear up your street tires at the strip and you don't compromise traction either.
