Im close to buying a set of...IFORGED EVO WHEELS..size 19/20...mounted, balanced with rubber....My question is...These are for my 97 coupe....Will they simply bolt right on or would I have to make a modification to the car for them to fit???? thanks for your help and time!!
Originally Posted by Y2Kvert4me
If you know they were specifically made for a C5/Z06...then yes.
Otherwise, not nearly enough info. Width, offset, bolt pattern?
You've got to find out more info on the wheels. I am running Imola 19/20s on my car with 245/35-19 and 285/30-20 tires and they fit just right. But, they were made for the C5.
