cahsis flex
Old Mar 13, 2006 | 08:54 PM
C5FLORIDA's Avatar
C5FLORIDA
Default cahsis flex
when i go over speed bumps even at very low speed the chasis seems to flex so badly, the dash mooves and sqeeks.
is there anything worng with my car or is this normal
Old Mar 13, 2006 | 08:59 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Not normal.
Old Mar 13, 2006 | 10:44 PM
countslav's Avatar
countslav
Flex on a C5....
Old Mar 13, 2006 | 10:51 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Originally Posted by Mike98SilVert
Not normal.
My Z51 vert is the most solid car I've ever owned.- and that was before I put in the backbone. If I were you I'd get that car up on a lift-but let someone else go under it in case it snaps in two. Have you had it since new? Do you know it's history?
Old Mar 13, 2006 | 10:56 PM
ddramz's Avatar
ddramz
Its not a salvage bought car is it, like does the paint on the front and rear match?
Old Mar 13, 2006 | 11:11 PM
nevadadave's Avatar
nevadadave
Wait a minute how big are the "speed bumps" that you are going over do they say toyota on them by chance. Cause that will cause the dash to squeek a bit
but seriously my 01 is so solid if i hit my driveway at the wrong angle i can lift one tire off the ground..... and the dash doesnt squeek.
Old Mar 14, 2006 | 12:36 AM
D_BlueVette's Avatar
D_BlueVette
not normal, get it checked out.
Old Mar 14, 2006 | 01:28 AM
'04 Z06 Rocket's Avatar
'04 Z06 Rocket
Only normal in a C4, NOT in a C5 !
Old Mar 14, 2006 | 06:52 AM
Dark-Knight's Avatar
Dark-Knight
Get her on a rack, quick!
Old Mar 14, 2006 | 07:00 AM
Does not sound normal to me. I'd get it checked.
Old Mar 14, 2006 | 11:29 PM
C5FLORIDA's Avatar
C5FLORIDA
i just got it in february from a Dealership here in South Folrida, 2001 Red Coupe all stock
Vin 1G1YY22G515119449, CARFAX report results clear with no problems reported
ill get it checket however hope its nothing major, althoe it sounds like it!
thanks for your outstanding help here in CF
Old Mar 15, 2006 | 12:03 AM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
The only time i get any squeeks is when I come up my steep driveway at an angle. It did it without the backbone, and does it much less with the backbone. Normal speed bumps, etc, are completely quiet, except rattling of my windows in their track, which i will fix someday.
Was your dash ever taken apart?
Old Mar 15, 2006 | 12:08 AM
Tru_Ice's Avatar
Tru_Ice
How many miles? Might need some suspension work.
Old Mar 15, 2006 | 07:33 AM
99C5Vert's Avatar
99C5Vert
62000 miles... Z06 suspension on a vert, which I'm sure doesn't help. the flex is very slight, but I do hear something flex in the dash area. The end of my driveway is steep enough that even at an angle, the front rubber air dam always scrapes.
Old Mar 15, 2006 | 08:46 AM
kidvette's Avatar
kidvette
I had a 2000 pewter coupe that I bought new and the body would flex when I would leave the steep grade parking lot at my job.I would notice it mostly around the roof panel. I even had stress cracks in the glass roof panel and got the chevy dealer to replace my panel.So these frames do flex a small amount. It is more prone to flex on the coupes and verts.Some coupe owners might want to check their glass tops on the outer edges for small stress cracks.
Old Mar 15, 2006 | 08:48 AM
LB04CE's Avatar
LB04CE
get it checked out..........
Old Mar 15, 2006 | 09:13 AM
RatedX's Avatar
RatedX
From: Spring Hill, Florida Life is all about new beginnings;...TRY ONE!
St. Jude Donor '07-'08
My '01 Red Coupe was 281 cars in front of yours on the assembly line and doesn't have a squeek or flex in it. Definately get it looked at!
To cahsis flex
