aussie clutch chatter
Old Mar 14, 2006 | 12:08 AM
STEEL's Avatar
STEEL
Default aussie clutch chatter
I just got my aussie clutch with aluminum flywheel installed, and I know they say aftermarket clutches chatter a bit, but mine seems to shack the car a bit. I was wondering if this is normal and I hope it passes. I have put 100 easy miles on the clutch so far.
Old Mar 14, 2006 | 12:20 AM
C5 KIDD's Avatar
C5 KIDD
Cruise-In VI Veteran
from what i read its normal, and that it goes away with some HARD driving. ive actually read that there is no "break-in" period for that clutch. basically they say break them in like break pads, few hard launches and you should be good to go!!
Old Mar 14, 2006 | 05:02 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Originally Posted by STEEL
I I have put 100 easy miles on the clutch so far.
that would be a first
whats up Arnold??
Old Mar 14, 2006 | 06:45 AM
Dark-Knight's Avatar
Dark-Knight
I know that lots of folks on the Forum swear by the Aussies, but I personaly know a couple who have had issues with 'em. Just an FYI...
Old Mar 14, 2006 | 12:44 PM
STEEL's Avatar
STEEL
not much robert, but I guess I will have to maybe drive it a bit harder.
Old Mar 14, 2006 | 05:23 PM
Vettegetsmwet99's Avatar
Vettegetsmwet99
mine did it two, it will be a lot worse than stock even after it is broken in, you get used to it and if you learn to take off at the right rpm then it wont chatter at all. once you learn the clutch and get a fell for it youll like it alot better. Just wait until until you get it broke in and you rip it hard going from first to second then it will be worth all the time and money. you will be amased by how much more this unit grabs over stock.
Old Mar 14, 2006 | 05:25 PM
mkiv808's Avatar
mkiv808
That is the nature of a lightweight flywheel. It does get better after break-in, but not much.
Old Mar 15, 2006 | 01:30 AM
STEEL's Avatar
STEEL
I have noticed when I take off at about 1,500 RPMs it doesent have any chatter. I have noticed that it does grip much better than stock.
Old Mar 15, 2006 | 08:07 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
No biggie. That just comes with the territory when you put in a race clutch. Cartek's does it as well when you take off at a certain rpm. It's all just part of the game.
To aussie clutch chatter
