Help!!! Zo6 Wheel Problem
Old Mar 14, 2006 | 08:00 PM
99TorchTop's Avatar
99TorchTop
Default Help!!! Zo6 Wheel Problem
I own a 99' hardtop and just purchased GM Zo6 wheels that had been chromed. At the same time my new wheels and tires were to be installed I had new brakes put on(calipers-rotors-pads). Two different tire stores have been unable to install the new front wheels because of clearance issues. Has anyone else had these problems??? Everywhere I've read the Zo6 wheels should go on a normal C5. Help!
Scott
Old Mar 14, 2006 | 08:05 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Never heard of this problem before... hmmm..
Old Mar 14, 2006 | 08:11 PM
gltrap54's Avatar
gltrap54
Default Should Work...........
I swapped out my wagon wheels on my 99' coupe for 04 Z06 wheels and F1 Supercars, even used my TPS on the new wheels. No problem! Not sure why yours wouldn't be the same.
Old Mar 14, 2006 | 09:37 PM
KonaVette's Avatar
KonaVette
St. Jude Donor '03-'04-'05
did the same on my 98
Old Mar 14, 2006 | 09:40 PM
army2000's Avatar
army2000
St. Jude Donor '11
What kind of calipers do you have???
Old Mar 14, 2006 | 09:56 PM
INaband's Avatar
INaband
CI 7-8 Veteran
Are they putting stick on wheel weights toward the outer part of the rim? This will interfere w/ the caliper, and the solution is install the weights toward the inside part of the rim......on the back rims the back calipers are smaller, so no issues there....
Old Mar 14, 2006 | 09:57 PM
Z28TOZO6's Avatar
Z28TOZO6
What kind of brakes? Some brakes need spacers for the rims so they clear them.
Old Mar 14, 2006 | 09:59 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Most of the big brake kits out there require 18" wheels.
More info as to what brake kit and what size wheels may get you a better response.
Old Mar 14, 2006 | 10:10 PM
MYCoupe's Avatar
MYCoupe
Are you sure they are GM wheels? Do they say Speedline on the back of the spokes? I'm only asking because if they happen to be repros the offset could be different fromt the stock offset and could cause interference issues. I know this is along shot, but worth looking into.
99TorchTop's Avatar
99TorchTop
Default zo6 wheel issue
The calipers are GM-red Corvette and the rotors are grip-force which are OEM size. Pads are by Hawk. Earlier someone mentioned weights on the rim which may actually part of my issue. When the wheels are turned to the left, I do hear a clicking noise on the left front wheel.
Also the tires are 275 up front vs. 265 spec on factory Zo6. Scott
Old Mar 14, 2006 | 11:05 PM
Midwest Vette's Avatar
Midwest Vette
Me too.
Old Mar 15, 2006 | 08:11 AM
INaband's Avatar
INaband
CI 7-8 Veteran
......i did, take the left wheel off and look at the weights or jack it up and spin the tire...
To Help!!! Zo6 Wheel Problem
