Stuck Up!
Old Sep 9, 2010 | 01:20 PM
76 VETTE's Avatar
76 VETTE
On my o1Z the drivers side parks perfect but the pas. side is about an inch from being hidden.I was going to just reposition it on the spline but after reading these posts I might just live with it.Good luck PassMe.Let us know how you made out.
Old Sep 9, 2010 | 01:31 PM
IceShadow's Avatar
IceShadow
Thanks man, you guys are awesome! I'll report the results after getting the thing in
Old Sep 9, 2010 | 01:32 PM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
It may be the spline on top where the arm is. There is one spline from the motor to the transmission piece where it goes to the splines on top of the cowell that the arms connect to. If one wiper is higher than the other I would re-adjust the that arm on top of the spline. (I hope that makes since, I'm hopped up on dayquill right now )
Old Sep 9, 2010 | 02:13 PM
krm_wi_C5's Avatar
krm_wi_C5
Originally Posted by madeouttaglass
no, No, NO! Stop! If you "reorient" the wiper arms on their shafts the next time you touch the key they will want to go into the engine compartment. If it were me, I'd ask the dealership what they were going to do and order the same parts used from Gene at Karshop or new from Fred Beans.
I agree, the wipers will go down instead of up when you re-orient them. This condition usually happens when the wiper blades are somehow restricted when you turn them on. I live in Wisconsin, this is common when there is heavy snow or ice on the windshield and the wipers are either left on from the day before, or they are turned on. It seems to me that a new motor will be needed. Maybe if you can DIY, you can save about half of the dealer estimate.
Old Sep 9, 2010 | 04:15 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Good advice.
Old Sep 9, 2010 | 05:23 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I took care of my windshield wiper problem about 3 years ago.
Old Sep 9, 2010 | 05:56 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
I'd hope so since she posted it in March of 2006
Originally Posted by FactoryRaceCar
I was curious, did you ever get this problem fixed? What was the cause?
