[Z06] Rollbar
Old Mar 17, 2006 | 12:41 AM
VinceAD's Avatar
VinceAD
Default Rollbar
I was wondering who has put a rollbar in their Z. (For track day/Solo) How difficult, can it be removed and put back in, etc?
Also, where can I find one?
Thanks,
Vince
Old Mar 17, 2006 | 06:47 AM
PA Z06's Avatar
PA Z06
I ordered one from R & D a forum vendor, have been waiting for 3 weeks for it, ill let you know how hard it is to install next week.
Old Mar 17, 2006 | 09:57 AM
HP_Addict's Avatar
HP_Addict
I have got a 5 point wolf bar. Good quality and fitment. It is a bolt-in bar, but not easily removable. Be sure to check the requirements for your event. Some require the the bar to be welded in. Depending on the track event you are doing, a rollbar might not be required.
www.wolferacecraft.com
Old Mar 17, 2006 | 11:10 AM
AU N EGL's Avatar
AU N EGL
There are a few place to get them Kirky is another. Not easy to put in and take out. Most ppl leave them in.
Old Mar 17, 2006 | 11:21 AM
FasterIsBetter's Avatar
FasterIsBetter
I just ordered a Kirk Racing roll bar from PFYC.com. Waiting for it to arrive. I'm going to have a local speed shop install it because the anchor plates need to be welded in. Then it's supposed to be bolt in, removable fairly easily. I'll let you know when I get it.
Old Mar 17, 2006 | 12:51 PM
VinceAD's Avatar
VinceAD
Thanks, let me know how it goes. I'm in not in a rush.
Vince
Old Mar 17, 2006 | 12:53 PM
VinceAD's Avatar
VinceAD
Let me know how it turns out.
Thanks!
Old Mar 17, 2006 | 03:07 PM
QUIK AG ZO6's Avatar
QUIK AG ZO6
I installed an AutoPower 4 point bar with harness bar and diagonal brace. There are 4 plates that weld to the frame and then the bar is bolted to the 4 plates with 2 bolts at each plate. Purposely ordered the harness bar and diagonal as bolt in pieces and they remove with one bolt at each end to allow a bit more luggage space. I think I would have to take the seats out to remove the bar itself. Had the bar black krinkle powder coated. It is a quality looking piece. It would have been better if the bar had a slightly rounded hoop bar to better follow the headliner. Since the hoop bar is horizontal at the top, it does take away from some of the rear view mirror vision.
To Rollbar
