I have stock polished rims on my coupe. I want to keep the runflats as plenty of tread left. Can I upsize the wheels to 18/19 or do I have to stay w/ stock 17" fronts and 18" for the rear? Thanks
Am I reading this correctly?
Are you asking if you can put your 17" front tires on 18" wheels and put your 18" rear tires on 19" wheels?????
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
You cannot put a 17" tire on an 18" wheel....etc. If you want to upsize the wheels (plus one conversion), you will have to buy new tires. Maybe this will help explain it a little better.....
Why not? Rubber stretches. Makes more sense than trying to put a 19" tire on an 18" wheel. Even that would work though come to think of it, after all he did say they are run flats. Wouldn't need to worry about keeping the air in.
