[Z06] Pumping up...
Old Mar 18, 2006 | 09:56 AM
yakisoba's Avatar
yakisoba
Default Pumping up...
This may be a silly question, but going to ask anyway. Do you guys use two different pumps for the differential and transmission fluid? Clean the pump between? Or is the amount of contamination so small that it doesn't matter?
--Yak
Old Mar 18, 2006 | 10:14 AM
Pumba's Avatar
Pumba
For the differential I use Mobil 1 synthetic differential fluid, and the bottles are flexible enough where I can squeeze them to inject the liquid.
For the trans I have one of the old battery fluid injection bulbs and I suck the fluid out of the bottle and inject it into the trans.
