Help with shift knob (posted in C5Tech also)
Old Mar 19, 2006 | 12:42 AM
RebelVette's Avatar
RebelVette
Default Help with shift **** (posted in C5Tech also)
I just got this **** and wonder if anyone else has this?
It installed easily, but it rotates quite a bit. Looks like the splines inside the **** are too narrow for the grooves. Just wondering if this is a quality control issue and I should return it for another, or if this is how they fit? I can probably shim it but don't want to if I can help it. If you rotate it enough times back and forth eventually the lock pin starts to come out. Thanks!
Old Mar 19, 2006 | 01:21 AM
JETZ's Avatar
JETZ
It shouldn't turn, send it back. It look's like a stainless piece to me, is it? If so, you're going to love it when the car has been sitting in the sun for a few hours.
Old Mar 19, 2006 | 01:24 AM
RebelVette's Avatar
RebelVette
Actually, it's brushed aluminum, hopefully won't be TOO hot.
Old Mar 19, 2006 | 02:00 AM
Hoosier Red's Avatar
Hoosier Red
It's going to be hot! Cover it with a baseball cap or something. Don't know about the threads though.
Old Mar 19, 2006 | 08:13 AM
Gitusum's Avatar
Gitusum
ive got the same **** on mine and it didnt rotate.i slid it on and tightened the hex heads on it and i was done! im thinking something is wrong with your ****
Old Mar 19, 2006 | 11:43 AM
rehirsch8's Avatar
rehirsch8
Your upgraded shift *** looks cool! I hope you get the problem fixed.
How do you get the stock A4 shift *** off? I am preparing to do the HUD upgrade and need to take the stock shifter off during the install but the instructions are for an M6.
Old Mar 19, 2006 | 11:47 AM
Gitusum's Avatar
Gitusum
i just did the hud install as well and i have a automatic and didnt have to take the **** off.
Old Mar 19, 2006 | 01:53 PM
MYRagtop's Avatar
MYRagtop
Give this a look
http://www.cau-llc.com/shiftknobinstall.html
To Help with shift knob (posted in C5Tech also)
