Could this cause some loud noises?
Old Mar 19, 2006 | 12:54 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Default Could this cause some loud noises?
Well, I was out there again, ripping this off of the car and inspecting parts for possible problems and if you have been following my issue (out lined here: http://forums.corvetteforum.com/show...258&forum_id=1 ).
Here are a couple of pictures of my air system tubing valve:
Notice the black residue, this is after I lightly rub my finger on it.
This would sort of explain why I can't hear it at an idle, but when I put load on it. I really wish I knew if this was it. And I have to wait until the dealership opens tomorrow, because none of the parts stores have it.
Old Mar 19, 2006 | 01:40 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
The black residue is from an exhaust leak....is this your noise? I don't know, but it's possible...and it's def. contributing to some noise in the engine bay. Toss on a bunch of RTV and throw it in the car, simple as that.
Chris
Old Mar 19, 2006 | 01:52 PM
NW_Vettes's Avatar
NW_Vettes
I can't see the pics but if it sounds like a sewing machine than it's the cam and is normal
Old Mar 19, 2006 | 02:00 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Chris
Chris,
This is something I was thinking of doing, which color would you go with? I have copper and black, but not sure if the "high" temp stuff is going to work with the exhaust because of the heat level.
To Could this cause some loud noises?
