[Z06] Road Force Balancing?
Old Mar 20, 2006 | 12:59 PM
pb24dagrk's Avatar
pb24dagrk
Default Road Force Balancing?
I'm installing my tires tomorrow (PS2's), and the shop I'm going to has the option for "Road Force Balancing"....is it a gimmick? He said the "higher end cars" require this....I told him I will let him know because I wanted to hit up the forums first.
For mounting, balance, road force balancing, and alignment check he's charging me $168.
Is this the equivalent of corner balancing or what? What is the difference?
Also, if I need an alignment, should I just go to the dealership or trust him/them?
Old Mar 20, 2006 | 01:09 PM
F1_SS's Avatar
F1_SS
IF you get an alignment, mount & road force balance then its a really good deal for $168.
Road force balance just simulated high speed conditions, and since you have a vette im sure thats why he suggested it.
Old Mar 20, 2006 | 01:10 PM
Z06-Goose's Avatar
Z06-Goose
Old Mar 20, 2006 | 01:12 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Standard balancing only checks for lateral movement of the wheel/tire assembly. Road force balancing matches the tire and wheel up the best so that it rolls true, it balances in the vertical direction too. The machine will tell them the exact orientation on the wheel of the tire for the best result. Sometimes they have to take the tire on/off a few times to get it perfect. It's the best balance.
However... the first launch you do... if the tire moves on the rim some it will negate that =)
Old Mar 20, 2006 | 01:28 PM
User 81424's Avatar
User 81424
Also, go to the FAQ and print out the alingment specs and demand accuracy not ranges. Use standard C5 specs if want longer tire life, but reduced steering feel and "handleing."
Old Mar 20, 2006 | 04:34 PM
vette217's Avatar
vette217
I had mine road forced balanced and have not had one vibration since done. That is a good price, I paid $180 and I thought that was cheap after getting quotes of $400 from Chevy dealers.
Old Mar 20, 2006 | 04:59 PM
exile's Avatar
exile
Old Mar 20, 2006 | 05:03 PM
Z06-Goose's Avatar
Z06-Goose
Would the same thing apply to tires you swap when racing? -assuming you then later put the stock wheels back on-
Goose
Old Mar 20, 2006 | 09:03 PM
LT1GMC's Avatar
LT1GMC
Road force balancing, which most Discount Tire as well as Tire Rack stores use, uses a balancer machine that has a roller which presses up against the tire as it spins while balancing, which indicates variations in the belt stiffness. That can cause vibrations, especially at speed. Yes, that vibration can often be minimized by tire matching, but a more IMPORTANT feature is it can indicate tires that are unsuitable for true high speed activities. My tire store went thru 7 tires to get 4 good ones for me to use in open road racing.( 90 miles at 150-165mph). Well worth piece of mind.
To Road Force Balancing?
