Ignition Swith Bezel Trim
Old Mar 20, 2006 | 02:28 PM
MrLeadFoot's Avatar
MrLeadFoot
Default Ignition Swith Bezel Trim
Does anyone know how the little bezel ring around the ignition switch attaches or fastens, if it even does? Or, does it simply sit around the switch, and rely on a pressure fit from the center console?
The reason I ask is because I recently noticed that my bezel ring was just flopping around, so I removed the interior temperature cover, and the single screw holding that part of the center console in. I pried that small piece of the center console trim back so I could see what was going on, but I can't determine how that little ring attaches to anything.
I can see that it flares out behind the console trim, and that it has what looks like some kind of tether on it like our gas caps, but the only thing I was able to do was just fit it around the ignition switch, and then screw the center console trim back over it for a pressure fit. I can still move the ring slightly if I put pressure on it with my thumb, but is that the way it's supposed to be?
If no one knows, can someone at least tell me if your little ring moves around slightly?
Thanks.
Old Mar 20, 2006 | 02:44 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Mine moves very very slightly. I also can not find a part # for it either. I must be looking in the wrong spot.
Old Mar 20, 2006 | 02:48 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
This may help:
These are install instructions from the VetteEssential's website. (God Bless Ken - You'll be missed )
http://www.vetteessentials.com/instr...zel_howto.html
The pics will give you a good idea of the construction.
Old Mar 20, 2006 | 02:53 PM
MrLeadFoot's Avatar
MrLeadFoot
Originally Posted by c5BlackBeauty
This may help:
I previously looked at those instructions, but they don't really show how the ring attaches to anything, if it even does, you know what I mean?
Old Mar 20, 2006 | 02:56 PM
MrLeadFoot's Avatar
MrLeadFoot
I can't even work the ring out from behind the console trim, even after removing the screw behind temperature sensor and prying the console back as far as I can, because of this little wire or tether attached to the ring.
Why do you need the part number, anyway? Does yours need to be replaced?
Old Mar 20, 2006 | 03:55 PM
mrC5er's Avatar
mrC5er
You have to get the entire IP panel trim off to get to the switch...not too bad of a job, I've had mine off a couple of times recently.
I've copied these instructions from my Alldata subscription, but I can't post the accompanying diagrams. Make note of step 7 as to the way the wire is wrapped. (To be honest, I don't know what this wire is, but is must be real important. )
1. Disconnect the negative battery cable.
2. Apply the parking brake.
3. Remove the console.
4. Remove the IP accessory trim plate.
5. Remove the driver knee bolster trim panel.
6. Remove the ignition switch lock cylinder electrical connector from the retaining tab on the side of the ignition switch.
7. Disconnect the lock cylinder electrical connector. IMPORTANT: Take note of the way in which the ignition switch lock cylinder wire is wrapped around the base of the ignition switch bezel.
8. Remove the ignition switch bezel. Carefully pull to unsnap.
Old Mar 20, 2006 | 05:52 PM
The parts manual I have (circa 2002) shows it as a separate part number - called a Bezel - Ignition Lock Cylinder (Part number 2852046). Price back then was somewhere around $9 for the part.
Old Mar 20, 2006 | 05:57 PM
MrLeadFoot's Avatar
MrLeadFoot
So, in a nutshell, sounds to me like the bezel just snaps onto the ignition switch somehow? I wonder why mine doesn't. Maybe I'm not interpreting the instructions right, cause if I place the bezel ring over the ignition switch it just sits there flush against the cylinder. No snapping onto the ignition cylinder seems even possible, yet it would seem odd that the only thing keeping it in place is that wire wrapped around the switch in certain way (since the wire is actually connected to the bezel ring), and a pressure fit from the center console trim. FWIW, I can't see any reason other than being a tether as to why that wire is even connected to the trim bezel ring. I guess it's a plastic ground.
Anybody ever actually removed or replaced an ingition switch/cylinder bezel? EVER?
Old Mar 20, 2006 | 05:59 PM
MrLeadFoot's Avatar
MrLeadFoot
I don't think I need the part, I need to know how it attaches to whatever it attaches to, if anything.
Old Mar 20, 2006 | 06:01 PM
MrLeadFoot's Avatar
MrLeadFoot
Thanks for that.
Anybody else care to let me know if their ignition trim bezel moves AT ALL? If so, how much does it move.
To Ignition Swith Bezel Trim
