[Z06] First timer here
Old Mar 20, 2006 | 11:03 PM
WM03ZO6's Avatar
WM03ZO6
Default First timer here
Recently bought a 03 EB Z mint 7300 miles with chromed Z06 style rims and a 84 month 7 year warranty paid 35K.I have read most of the posts over the last six weeks and this site has been very helpful being a first time Vette owner or sports car period.The only major weakness my 03 (built in 02)has is the aluminum shift fork or forks.Can someone explain to me the purpose and how the shift forks work.Can my mechanic friend and I replace the aluminum forks with the metal ones or is this a complicated procedure that a shop should do.
Old Mar 21, 2006 | 12:29 AM
'04 Z06 Rocket's Avatar
'04 Z06 Rocket
Old Mar 21, 2006 | 01:07 AM
B R's Avatar
B R
From: Los Angeles, CA.... I know a guy who has a Lambo with Corvette doors
So do you have a problem with your trans? If yes, then since you said you have a warranty, that's what it's for, to fix problems. If you don't have any problems, why deal with it now? If you have a problem in the future, then use your warranty then. You did say there was 7 years left on it, riiight!
Old Mar 21, 2006 | 01:13 AM
Shylor's Avatar
Shylor
Last I knew Aluminum is metal.
Old Mar 21, 2006 | 02:33 AM
Miguels's Avatar
Miguels
welcome...congrats...where from?
btw, I don't know...just driving by...
Old Mar 21, 2006 | 09:12 AM
TYZ-TOY's Avatar
TYZ-TOY
Congrats... Nyce choice of colors....
Old Mar 21, 2006 | 09:52 AM
User 81424's Avatar
User 81424
Welcome! If you don't have a problem shifting then there is no need to upgrade to the steel forks. Just enjoy the car and don't use unnecessary force to shift it.
Old Mar 21, 2006 | 10:05 AM
bluestreak63's Avatar
bluestreak63
Hey folks, maybe we should take it easy on the new guy. He just asked a couple of simple questions which warrants simple answers. I'm sure he's fully aware he's got the warranty and knows nothing is wrong with it now, but wants to proactively take care of the issue before it comes to haunt him (if it even does). I mean do you like to take your Z's to the dealer? No. And for those who got CLB's, why did you get them? Was anything wrong? No. You just took preventive action.
So if someone in the know could just answer his question, which was what the purpose of the shift fork is, how it works and can it be replaced by a non-chevy mechanic in a garage on the side.
By the way, congrats on your Z...have a blast with it...
Old Mar 21, 2006 | 12:10 PM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
Geez Louise,
The guy just asked a question. Welcome to the forum. I would'nt worry about the shift fork at all!
Old Mar 21, 2006 | 12:51 PM
Pio's Avatar
Pio
Welcome to the forum!! I wonder if you were to bend a shift fork, if they would replace it with the steel one?
Old Mar 21, 2006 | 03:15 PM
slong's Avatar
slong
Welcome. Hopefully the fork will last until it's time for clutch work and then you can do several upgrades in that area. Good luck.
Old Mar 21, 2006 | 04:27 PM
t56gen3's Avatar
t56gen3
Last I heard the steel forks ARE the replacement forks for all years. So if one gets bent, and the tranny warrantied, the replacement SHOULD be the steel one.
Old Mar 21, 2006 | 04:45 PM
Nithros's Avatar
Nithros
St. Jude Partner since 89
St. Jude Donor '09
Welcome to the forum. I assume your shift forks are in pristine condition since it is shifting without problems. May I suggest a Hurst aftermarket shifter with the gear stops to prevent future problems.
Old Mar 21, 2006 | 06:50 PM
WM03ZO6's Avatar
WM03ZO6
Thanxs bluestreak63 it is preventive maintaince or piece of mind to replace S.Forks and if it is easy to do.. why not? Does anyone have any info on the hurst shifter with gear stops;price,installation,how it feels when shifting and how noisy is it?
Old Mar 23, 2006 | 04:54 PM
B R's Avatar
B R
While you are at it, you might as well change out your pistons & rings .
Old Mar 23, 2006 | 07:13 PM
Scott04Z's Avatar
Scott04Z
From: I'm not quite middle aged and I only own one gold chain! San Jose CA
Welcome to the forum and congrats on the purchase of your Z06. I bought mine new in 04. It is my first Vette and I love it! You will find this to be a helpful site with the occasional smart#%* present from time to time like all sites, but overall this forum is a great place to get help and some pretty great comic relief too, but don't tell the moderators!
Old Mar 25, 2006 | 12:13 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi WM03ZO6 -
Without too much detail - your transmission works by a series of gears riding on separate shafts, mating on each other.
The gears have "dogs" machined into them in such a way as they can "interlock" when they are pushed together -
When you move the shift lever, you are actuating this sliding motion on the gears.
The "forks" are the pieces that push against the gears to slide them back and forth, thus causing different combinations of gears to be mated and in turn vary the gear reduction.
As said above - don't worry - be happy, and if it becomes a problem, address it then.
Welcome and congrats!
best regards -
mqqn
To First timer here
Old Mar 25, 2006 | 11:46 AM
straatien's Avatar
straatien
I'll be the lone dissent here. I was on a nice drive in the mountains, far from home and any repair shop when I bent the aluminum shift forks in my '02. Being the second owner I didn't have a warranty. It cost me just under $3K to get the repair done. I recommend having the work done at your convenience before you're inconvenienced in the middle of no where. Imagine being the driver responsible for stopping a caravan on it's way to the Z06 'fest because your shift forks bent while passing through BFE. Your aluminum forks may never bend but I recommend peace of mind. Better to have and not need than need and not have.
Old Mar 25, 2006 | 02:34 PM
badass7's Avatar
badass7
Greetings fellow Z bro's. New '02 MY owner here as well. I was wondering if the hurst shifter with gear stops is the way to go to prevent any bending of forks, and for that matter knives and spoon
Def. don't want to run into the problem that straatien ran into !!
TIA
Old Mar 25, 2006 | 03:16 PM
Roadking's Avatar
Roadking
Welcome the the family enjoy the
