Hurst Shifter Question???????
Old Mar 21, 2006 | 12:48 PM
PashaCorvette's Avatar
PashaCorvette
Default Hurst Shifter Question???????
Hi Guys
I have the hurst shifter and evrything and also know how to install it too but only problem is i don`t have the original hurst shifter gasket.I was surfing around on the net but couldn`t find just the gasket.What can I use as an alternative, instead of original gasket.Or anybody knows the website that I can order.Any thoughts will be helpful thnks......
Old Mar 21, 2006 | 01:10 PM
PashaCorvette
ttt
Old Mar 21, 2006 | 01:12 PM
TEXHAWK0's Avatar
TEXHAWK0
Not sure you even need one except to compensate for irregular mounting surfaces.
I am looking at the Hurst gasket and it just looks like common gasket material (resembling thick paper, not rubber) that is about 1/16 inch thick. You could use the base of the shifter as a template and easily cut your own. The factory gasket was thinner and more like rubber, so I would think that thickness was not critical.
Old Mar 21, 2006 | 01:34 PM
PashaCorvette
thnks
Old Mar 21, 2006 | 05:03 PM
PashaCorvette
anymore ideas????????
Old Mar 21, 2006 | 08:27 PM
sage666's Avatar
sage666
I've been the Hurst route and encountered a torn gasket. I just used a tube of silicon gasket repair to hold it together. When I got tired of the hard shifting and put the stock unit back in, the "stuck" gasket was still in place and fine, so I reused it.
Old Mar 21, 2006 | 08:33 PM
chargedsol's Avatar
chargedsol
i used silicone gasket when i installed mine as well.
Old Mar 21, 2006 | 09:03 PM
PashaCorvette
Pardon my French But where can i get that silicone gasket?
Old Mar 24, 2006 | 10:56 PM
TEXHAWK0's Avatar
TEXHAWK0
I think they are referring to silicon "form-a-gasket" that comes in a tube, and you can get at any parts store. The gasket is not really sealing anything, so unless you cut a gasket out of gasket material just to absorb any surface irregularities, I would not think you would even need a gasket.
To Hurst Shifter Question???????
