Help!!! Window Valet gone wild?????
Old Mar 21, 2006 | 08:28 PM
Vette 4 Fun's Avatar
Vette 4 Fun
Default Help!!! Window Valet gone wild?????
Last week when I went to lock my Vert, everything went nuts!!! Windows went up and down, doors would not lock, but would unlock over and over… after a few minutes I thought to check the Window Valet, it seemed not to be plugged in all the way, so I unplugged it and replugged it in.
All seemed back to normal, but today when I went to lunch I locked the doors as normal, windows were up. When I came out, 1 hour later, both windows were down, but the doors were locked which rules out acciently hitting the FOB 3 times…I did not think much of it, just scratched my head and went back to work.
When I came out of work 4 hours later, yep, both windows were down and the doors were both locked, checked the Window Valet, it was NOT loose this time at all…
So what do you think, is it a faulty Window Valet??? Has this ever happened to anyone else??? I am just glad that the rain was yesterday, and not today!!!
Old Mar 21, 2006 | 08:38 PM
hardtop's Avatar
hardtop
hate chasing wires.
Maybe try a relearn, or reprogram for the windows.
Old Mar 21, 2006 | 08:53 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
if your valet was unplugged for a while , you may have to re-learn the window roll up travel setup .
now every once and a while when I hit the lock 3 times , mine will roll up , and come back down for no apparent reason , then stay up if i roll them up again . I love the valet , but I never just hit the lock 3 times and walk away , you never know , I keep an eye on the windows to make sure they stay up then walk away . a habit worth having .
Old Mar 21, 2006 | 09:12 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
Twice now, I've come back out to my car and the windows are all the way down. I just took the Window Valet out for now.
jeff
Old Mar 21, 2006 | 09:23 PM
man00dude's Avatar
man00dude
St. Jude Donor '09
Wish I could help but.. Can't. I purchased a 2000 coupe with the window valet installed. But I dont have the instrucgtions. Does anyone know where i can find a copy?
thanks
Old Mar 21, 2006 | 10:38 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
thanks
Try this
http://eliteengineeringusa.com/WV-100C5.pdf
Old Mar 21, 2006 | 10:54 PM
MrLeadFoot's Avatar
MrLeadFoot
Maybe the Column Lock gremlin is contagious. Just kidding. Sorry I couldn't resist. Flame on!
Old Mar 22, 2006 | 02:13 AM
Vette 4 Fun
You should be banned for life for that comment!!
Old Mar 22, 2006 | 02:14 AM
Vette 4 Fun
jeff
Jeff: How long have you had your WV?? I have had mine around a year, maybe a bad batch???
Old Mar 22, 2006 | 02:39 AM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
I agree on reprogramming the windows on the Window Valet. If the windows are partially down, and you use the WV to close them, they will roll back down because the WV wants to see full travel and if it encounters what it perceives to be an obstruction (like your top), they will roll back down. Just make sure that when you use the three click fob action to roll up the windows, make sure they are FULLY down first.
I still keep an eye on the windows before I walk away from the car, but have had no problems.
Old Mar 22, 2006 | 06:01 AM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Wierd! Don't overlook a battery going bad. When they do all sorts of strange things can happen.
Old Mar 22, 2006 | 07:24 AM
JeffC5's Avatar
JeffC5
I think it's been about a year since I bought mine. It could be a bad batch or.....maybe we dont know how to program them correctly? LOL
Seriously, I think I've programed mine correctly. I just think it doesn't work good. I loved hitting the remote 3 times and having the windows roll down and hitting lock 3 times and having them roll up. Just couldn't trust it after finding the windows down a couple of times.
jeff
Old Mar 22, 2006 | 07:30 AM
gredmer's Avatar
gredmer
I've noticed if the windows are dirty the friction while closing causes the windows to stop and go back down. Clean the windows and it works fine.
Old Mar 22, 2006 | 07:35 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
You just need to reprogram the windows.
Old Mar 22, 2006 | 08:04 AM
DeeGee's Avatar
DeeGee
I've also had it happen twice.
First time was my own fault as I hadn't latched the top.
Second time was last week and I had to select 3 times before the windows stayed up.
I've also had mine about a year. I'll see if it happens again but maybe a relearn will work.
Old Mar 22, 2006 | 09:42 AM
Vette 4 Fun
jeff
The strangest part is both times did not I use the fob to roll up the windows, the windows were already up so that rules out any issues about mis-programming or dirty windows…
I think I will send an email to the maker and see what happens
Old Mar 22, 2006 | 09:49 AM
Yoggi's Avatar
Yoggi
To Help!!! Window Valet gone wild?????
Old Mar 22, 2006 | 09:54 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Old Mar 22, 2006 | 10:28 AM
man00dude's Avatar
man00dude
St. Jude Donor '09
Originally Posted by pcfred
Thanks PCFRED.
Old Mar 22, 2006 | 10:37 AM
Plentyfast's Avatar
Plentyfast
Same thing happened to me, when I let my battery go down over the winter.
Just reprogram ... and you're back to normal.
