[Z06] Peak Rpm
Old Mar 22, 2006 | 08:22 PM
HACKSAW's Avatar
HACKSAW
Default Peak Rpm
I Had Problems With My Vararam And You Guys Have All Really Helped Me Out.
Along With The Vararam Problem I Asked About The Safe Peak Rpm For A Stock 03 Z06.
The Tech Who Installed My Vararam Set Mine At 7000.
Any Thoughts?
Old Mar 22, 2006 | 08:25 PM
Andy64's Avatar
Andy64
I think most will say the safe peak RPM for the LS6 (Stock) would be the 6500 it normally is set to. Without some internal upgrades, I dont think much more is wise for any sustained run.
Old Mar 22, 2006 | 09:10 PM
oupike1757's Avatar
oupike1757
Stock rev limiter is 6600, and most tuners will bump it up to 6800.
Old Mar 22, 2006 | 09:54 PM
402Sam's Avatar
402Sam
7100 but I have upgraded valve train. But even with a aftermarket tranny, synchos dont like alot more above 6700.
Old Mar 23, 2006 | 06:50 AM
AU N EGL's Avatar
AU N EGL
GM did a test on the LSx motor at 6900 for an extendided time with no major problems. the World challange LSx motors have the redline bumped to 7400. No matter what valve train you use, there is still some valve float above 65-6700.
If your not changing your valves to the LS6 titanium springs keep the rpms down 65-6700.
Old Mar 23, 2006 | 07:58 AM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
Well spoken as always. Great advise!!!
Dave
PS Mine is set to 7100 but my entire valve train has been upgraded but rockers and lifters. Stock set-up, it's best to shift @ 6500 for best track times (1/4). I belive most road race folks go @ 6k but then again, then man to ask is right there above
Old Mar 23, 2006 | 06:57 PM
HACKSAW's Avatar
HACKSAW
Default Rpm
Thanks A Lot For Your Input - I Think I'll Have Mine Turned Back A Bit.
Again!!
To Peak Rpm
