Wheel balancing
Old Mar 23, 2006 | 11:04 AM
TheBigDog's Avatar
TheBigDog
Default Wheel balancing
Does anyone know of anyplace in Ohio preferably the Columbus area that does road force balacing on wheels. Jut installed a new set and I want to get this process done
Thanks,
The Big Dog
Old Mar 23, 2006 | 11:31 AM
tiojames's Avatar
tiojames
Default balancing
Get on the net and look up balancing. The company that does road force machines lists all the tire shops that use their machines by zip code.
Old Mar 23, 2006 | 12:52 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Here is a link to Hunter's web site - this page will help you find a local rep, who can tell you who in your area has their systems....
http://www.hunter.com/pub/company/findrep.htm
Old Mar 23, 2006 | 07:38 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
Your local Discount Tire should have it.
Old Mar 24, 2006 | 11:01 AM
98TightyWhitey's Avatar
98TightyWhitey
so this isnt just a gimmick...i am about to get brand new wheels and tires put on...should i get this done?
Old Mar 24, 2006 | 02:12 PM
tiojames's Avatar
tiojames
Default Road force balance.
Not a gimmick. Machine can load wheel up to 1400 lbs. Lets operator check how tire performs under load. Having mine done as soon as Tire Rack delivers them.
Old Mar 24, 2006 | 03:28 PM
vettecop1125
CI 7-8 Veteran
Old Mar 24, 2006 | 03:31 PM
fsa00120's Avatar
fsa00120
I agree with you have the tires road forced balanced
Old Mar 24, 2006 | 03:52 PM
rws.1's Avatar
rws.1
This is the correct link to follow to locate a Hunter Road Force balance near you.... follow the link and type in your zip code
http://www.gsp9700.com/pub/search/FindGSP9700.cfm
Old Mar 26, 2006 | 08:06 PM
98TightyWhitey
so i had this done and i am pretty sure my wheels and tires are not properly balanced. 3 of the wheels have a lot of weights added to them and the wheels are brand new. from 60mph and up i get a periodic pulsing thing going on. it will ride smooth but then every 3 seconds it will fade in and then fade out and so on...any ideas?
thanks
phillip
To Wheel balancing
