Need help quick
Old Mar 23, 2006 | 09:26 PM
bentonmike's Avatar
bentonmike
Default Need help quick
Hi everyone, I went to leave for work this morning and discovered that I had left my map light on last night, the battery was dead as a door-****. When I got home from work I put the charger on it and everything is working fine except the check engine light is on. Any ideas why? and what I can do to make it go off. I'm leaving for Chicago in the morning, that's the reason for the rush. Thanks in advance...Mike
Old Mar 23, 2006 | 09:37 PM
rgtkst's Avatar
rgtkst
what does the voltage meter read? did you jump start the car the correct way? if you hooked it up wrong for even a brief second you could have blown the altenator. causing low voltage to show thus the check engine light. if it is not full charge possibly something similar.
Old Mar 23, 2006 | 10:42 PM
bentonmike's Avatar
bentonmike
Default Thanks
No, I didn't need to jump start it, I just hooked up the charger and let it charge for about three hours. A buddy of mine who works for chevy suggested uhooking the battery cable for a while, I tried it and it worked. Thank you for the quick response, and have a great weekend...Mike
Old Mar 23, 2006 | 10:44 PM
rgtkst's Avatar
rgtkst
good for you. an easy fix. have a great trip, drive safe
rt
To Need help quick
