VIN code for performance axle for A4?
Old Mar 23, 2006 | 09:54 PM
red98a4's Avatar
red98a4
Default VIN code for performance axle for A4?
What is the VIN code for the 3.15's gears on the C5s? Where does it begin and end the the VIN?
Old Mar 23, 2006 | 10:02 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
It's not in the VIN. It's on the RPO (Regular Production Option) sticker that's probably on your glove box door. The code is G92.
http://corvetteactioncenter.com/spec.../2001prod.html
Old Mar 23, 2006 | 10:20 PM
red98a4's Avatar
red98a4
Not in the glove box...where else would it be?
Old Mar 23, 2006 | 10:29 PM
VetteLag00's Avatar
VetteLag00
I am suprised it's not there
It should be a sticker on the inside of the glove box door.
I just posted this a few minutes ago, hope this helps.
http://forums.corvetteforum.com/show...3&forum_id=103
Old Mar 23, 2006 | 10:30 PM
blacksedan87
Check under one of the rear side cargo compartment lids. Now that I see your screen name, I surmise that you have a red 98 with an A4
Oooops, shoulda caught that first time around! :o
Old Mar 23, 2006 | 10:41 PM
VetteLag00's Avatar
VetteLag00
That explains it. My 00 is in the glove box, I had no idea it changed between 98 and 00. Boy do I feel stupid.
Old Mar 23, 2006 | 10:52 PM
blacksedan87
Don't feel stupid - how would you have known that? I know that because I have a '98.
Old Mar 24, 2006 | 07:28 AM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
Vin Code info
http://c5.techbottle.com/vin.htm
Old Mar 24, 2006 | 01:20 PM
qwerty11's Avatar
qwerty11
So how much does the performace axle help?
Old Mar 24, 2006 | 01:28 PM
JoshVette's Avatar
JoshVette
Just go stick your head under the butt of the car and get a flash light, that's the best way IMO.
Old Mar 24, 2006 | 02:20 PM
KidCid's Avatar
KidCid
CI 7-8 Veteran
Enough of a difference that it was a "must have" option for me when I bought mine. YMMV.
Old Mar 24, 2006 | 02:31 PM
Sully C5's Avatar
Sully C5
For 2001:
....Rear.... 0-60 MPH....1/4 Mile
A4 2.73.... 4.90 Sec.... 13.65 Sec
A4 3.15.... 4.75 Sec.... 13.50 Sec
Pre 2001 was ~0.25 seconds less in the 1/4
Old Mar 24, 2006 | 07:08 PM
red98a4's Avatar
red98a4
Ive got the 3.15 Perfomance Axle! The service parts indentification has both G90 and G92! Bought the car less than two weeks ago!!! What a great surprise! How much quicker would it be with 3.45s???
Old Mar 24, 2006 | 10:01 PM
JH's Avatar
JH
Let's put it this way: the later model C5 A4 cars have 1/4 mile times comparable to the earlier C5 with a M6 transmission. Remember, the later C5 had adjustments to the HP and torque curve that meant the 3:15 rear axle on the A4 really RIPS!!!
Old Mar 24, 2006 | 10:11 PM
Sully0212's Avatar
Sully0212
Default RPM vs MPH chart
Check out this RPM vs MPH chart to compare all the gear choices.
Got this from another forum member.
Sully
To VIN code for performance axle for A4?
