Speed Limiter?
Mar 24, 2006 | 10:30 PM
Speed Limiter?
Do the C5's have any kind of speed limiter, or will they go as fast as they will go? What is the top speed of a C5 6MN? I think I've read something like 176mph somewhere.
For instance, my Audi A6 is supposedly electronically limited to 135mph, and shuts down at that speed...not that I've ever tested it.
Mar 24, 2006 | 10:39 PM
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
The PCM goes to 255 mph (Hex : FF)
That is the only limiter on the C5
Aerodynamics, gearing, redline and horsepower are your only other limiting factors
Mar 24, 2006 | 11:00 PM
The most important limiting factor is the nerve of the driver.
Once you get above 160, you can run out of room in a hurry.
Mar 24, 2006 | 11:17 PM
No limiter.
172-176 in 5th gear.
Mar 25, 2006 | 03:36 AM
I was with a friend in his C5 MN6 and we tested out 3 of the new freeway cameras at 3am and got 181 mph on GPS. I dont even think the car was in the picture!!! And man there was serious wind noise.
Mar 25, 2006 | 04:19 AM
yea no limiter, they're drag limited
Mar 25, 2006 | 06:24 AM
Cruise-In VIII Veteran
St. Jude Donor '07
Mar 25, 2006 | 07:37 AM
No limiter that I have heard of. I remember seeing something in print that stated the top speed for a coupe was around 175 mph.
Mar 25, 2006 | 07:44 AM
Quote:
Originally Posted by rwsr50
Do the C5's have any kind of speed limiter.
Yes. Absolutely, but I usually leave mine at home. The wife hates riding in the vert.
Mar 25, 2006 | 09:10 AM
Thanks for the replies. It's good to know. I was just curious. However...I have NO plans to test it!
Mar 25, 2006 | 11:34 AM
limiter
No limiter, only redline shut off on RPMs.
Mar 25, 2006 | 01:41 PM
Cruising
No Limiter Just Wind Noise
Stage 1 Lingenfelter Tt Auto Vert
198 On Hud And Gps
Noise Beyond Crazy
Chris
Mar 25, 2006 | 01:44 PM
Quote:
198 On Hud And Gps
Noise Beyond Crazy
Chris
Top up or down? That must have been one wild ride either way. Did the speed volume control on the radio do it's job, ha, ha.
Mar 25, 2006 | 07:04 PM
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Quote:
Good one.
