Get Codes from DIC
Old Mar 25, 2006 | 06:38 PM
freemanjc's Avatar
freemanjc
Default Get Codes from DIC
Can somebody tell me how to retrieve codes on my 98 C5! After my Heads and Cam install I am getting SERVICE ENGINE SOON, but can't find out the codes. Instructions would be nice. This has been a nightmare. Now my radion will not play, I am gtting no power to the amps or radio and have a oil leak under the car somewhere.
I am so upset!
Old Mar 25, 2006 | 07:02 PM
freemanjc's Avatar
freemanjc
Can anybody tell what these codes mean, specifially 80-Radio. My radio is not working anymore!
80-Radio - Radio Not Found
B0521 Tachometer Signal Circuit Malfunction (HISTORY)
P1281 APP Sensor 2 Circuit Performance ( H)
P1286 APP Sensor 3 Circuit Performance ( H C)
P1431 Fuel Level Sensor 2 Circuit Performance (H)
P0441 EVAP System No Flow During Purge (C)
B2262 Horizontal Position Sensor Fit
Old Mar 25, 2006 | 07:05 PM
DeeGee's Avatar
DeeGee
Here ya go:
http://www.97vette.com/howto/codes/index.html
Red on black's a bit difficult to read but good info
Old Mar 25, 2006 | 07:11 PM
jman1's Avatar
jman1
damn... did you try posting in the tech section?..... i'd say the radio was unplugged....was you in there doing anything??
Old Mar 25, 2006 | 07:15 PM
DeeGee's Avatar
DeeGee
I got the 80 code when I got rid of the stock radio and fitted my AVIC N1.
The PCM tries to communicate with the radio for the speed/volume function and it can't see it.
I'd say you've lost the connection.
Old Mar 25, 2006 | 07:18 PM
freemanjc's Avatar
freemanjc
It is throwing Code 80 no communication.
All this stuff happened after my H/C, 3200 Stall, 3:42 Diff etc........
How can the radio not play, what does that have to do with anything! I need some help!
freemanjc's Avatar
freemanjc
How do I get back connection. It's just a simple Kenwood CD Player! I wonder if the EFI live tune change a setting about the radio?
Old Mar 25, 2006 | 07:22 PM
DeeGee's Avatar
DeeGee
Do you still have your stock radio as well as the Kenwood CD player?
Old Mar 25, 2006 | 07:27 PM
freemanjc's Avatar
freemanjc
I just have the Kenwood radio!
Old Mar 25, 2006 | 07:29 PM
DeeGee's Avatar
DeeGee
In that case the 80 code is what you'd expect. The PCM is looking for the stock radio and can't see it.
If your radio is dead I guess you need to start troubleshooting the connections and fuses.
The fuse for the radio is in the footwell - fuse #5. Other functions have other fuses such as the Bose speakers and the antenna.
Old Mar 25, 2006 | 07:48 PM
freemanjc's Avatar
freemanjc
Degee!
I am not following. I checked the fuse for the radio and it is good! THis all happened two days after my install, so how can it just go faulty. It went out yesterday and when I got in the cat this morning it started working fine. Today I go to take a drive and it went out while I was driving and has not come back on since. Is there a way to reset it. Should I disconnect the battery and connect it again?
R/
Free
Old Mar 25, 2006 | 07:49 PM
freemanjc's Avatar
freemanjc
How did you get your radio working after the code?
Old Mar 25, 2006 | 08:20 PM
freemanjc's Avatar
freemanjc
Anyone!!!!!!!!!!!
Old Mar 25, 2006 | 10:00 PM
DeeGee's Avatar
DeeGee
The 80 code is a Red Herring. If you took out your stock radio you can expect that
My AVIC can play hard to get at times. There are so many wires back there that things get pinched and the radio quits
Pull it out and check all the wires are connected. If it comes back to life, chances are you have a bad connection. If not, I'd reconnect all the wires starting with the obvious like Live, ground and so on.
To me if its completely dead it must be a fuse, ground or a power wire. If it was a speaker out you would at least have something. Try to Bose fuse # 20 something.
Old Mar 26, 2006 | 11:49 AM
TLKSCHP's Avatar
TLKSCHP
If it doesn't work out by the time you get here we will fix it then.
To Get Codes from DIC
