Lowered Car
Old Mar 26, 2006 | 09:14 AM
jet2vettes's Avatar
jet2vettes
Default Lowered Car
When a car is lowered, assuming on stock bolts, are there any alignment issues or handling concerns that should be addressed? Is tire wear an issue? Lastly, is there a way to measure if a car has been lowered?
Old Mar 26, 2006 | 10:04 AM
Vettegetsmwet99's Avatar
Vettegetsmwet99
you definatly need an alignment when you lower because if you dont your tires will wear on the inside. handling will be a little better and a little tighter, but ride doesnt change very much, you can measure from the ground to the bottom of your fender on all four tires before and after to see how much it dropped.
Old Mar 26, 2006 | 10:09 AM
artfahie's Avatar
artfahie
It cost me $$$ for an alignment and the guy who did it said it was a "jugement" call... he did some "tweaking" but there was no serious problem driving it the way it sat... even with it being lowered on stock bolts ! It's better to have it checked, but I was suprised to hear of only a minor-adjustment being needed ! ... BUT, it still cost me $$$$.... no free-rides here ! (It was in almost perfect alignment before the lowering, I had the tires examined before I had my new ones installed !)
Old Mar 26, 2006 | 11:15 AM
MrHiPerf's Avatar
MrHiPerf
Default How much exactly, in American dollars,
does $$$ represent? Call me stupid, but I missed the part where $ = X dollars. Seriously though, how much Alignment shops charge would be a good thing to know. Maybe someone near you charges a lot less for the same job. I would like to know who, in Central Jersey, does a proper alignment at a reasonable price.
Old Mar 26, 2006 | 01:10 PM
jet2vettes's Avatar
jet2vettes
Thanks for input. It would be helpful to the know the cost of a good alignment. Is there a way to measure if a car has been lowered. I suspect that a car I'am looking at is lowered, but the owner says it hasn't been. Just would like to check.
Old Mar 26, 2006 | 03:26 PM
jrose7004's Avatar
jrose7004
My alignment cost $90.00 after lowering!
Old Mar 26, 2006 | 05:04 PM
VetteSiNz's Avatar
VetteSiNz
Me too, I got charge $90.
Old Mar 26, 2006 | 05:18 PM
jet2vettes's Avatar
jet2vettes
Not too bad. Thanks.
Old Mar 26, 2006 | 05:51 PM
tiojames's Avatar
tiojames
Default alignment
Alignment prices vary from place to place. Also some shops have different equipment than others. I suggest you call around in your area to get quotes. Be sure and ask if they have done C5s. In my case when I lowered it on stock bolts it did not need re-aligning.
Old Mar 26, 2006 | 06:03 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
I had mine done at the dealership after driving about 200 miles with it lowered. It was just a bit out of alignment. They said the tires would have worn quickly the way it was. The alignment cost 79.00. I took my 2x6 peices of wood so they could drive it onto the alignment machine, but they had their own boards to use.
jeff
Old Mar 27, 2006 | 12:00 PM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
$90 at any height in Central Alabama.
Had trouble getting car on rack, finally found a place that could get it on. Best bet, look for a drive on, i.e. lowered pit alignment setup, there are two places in Bham that have the pit type.
I went boltless up front, longer in rear.
Hope this helps.
Old Mar 27, 2006 | 01:31 PM
jet2vettes's Avatar
jet2vettes
All your comments are greatly appreciated. Thanks.
Old Mar 27, 2006 | 01:35 PM
barrynk's Avatar
barrynk
I lowered mine on the stock bolts a few weeks ago, and had it aligned at a local firestone shop. Price was $70 or $148 for lifetime alignment. I went for the $148, figuring it will need alignment at least once more as long as I own it.
Old Mar 27, 2006 | 01:45 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi jet2vettes -
I recommend having the alignment checked. Wit hte cost of the tires on these babies, that is money well spent.
Figure on ~$100, commensurate on the amount of adjustment that has to be done....
To see if your car has been lowered, look under the back-end of the car on one side or the other. Locate the rear lowering bolts and see if the nut is at the top of the bolt (what would be the end of the threaded end - upward from the ground...).
If there is very little of the threads showing on the top side of the nut, then the car has been adjusted down.
best regards -
mqqn
Old Mar 27, 2006 | 01:51 PM
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
sounds like ya got your answer.
Enjoy
Rain
Old Mar 29, 2006 | 01:45 AM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi Rain -
Nice new sig here!
best regards -
mqqn
Old Mar 29, 2006 | 06:31 AM
Dark-Knight's Avatar
Dark-Knight
I agree in that you should have a alignment after the car is lowered. Tires are too expensive to not play it safe.
To Lowered Car
