Has Anyone Tried....
Old Mar 26, 2006 | 07:08 PM
CorvetteGirl-NM's Avatar
CorvetteGirl-NM
Default Has Anyone Tried....
I would like to get a dash letter kit (for the airbag) but can't find any in pewter. Has anyone tried getting white then painting them with touch-up paint? I'd like the lettering to match the exterior color.
Thanks!
Old Mar 26, 2006 | 07:16 PM
Pizzano's Avatar
Pizzano
Just spray them while still being stuck on the application sheet, this way no brush strokes, and a lighter coat will look much more proffesional.
Old Mar 26, 2006 | 07:19 PM
CorvetteGirl-NM
Thanks!
Old Mar 27, 2006 | 08:37 AM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
Can't you just paint the recessed area of the letters on the dash? I thought I remembered seeing a few people do that with pretty good success.
Old Mar 27, 2006 | 08:53 AM
OUR97's Avatar
OUR97
I did it because I couldn't find Firethorn Red. Just get the color of choice and a small artist brush. Use a steady hand and go for it. It is easy to stay inside the lines. I used water based paint for easy cleanup.
[IMG][/IMG]
Old Mar 27, 2006 | 08:54 AM
DeeGee's Avatar
DeeGee
I tried painting directly into the letters. I used the standard GM Mag Red touch up paint
It looked good for a few weeks and then peeled. I had to take it off
Dont know if the paint didn't like the plastic surface or if it was the Vegas summer heat
Old Mar 27, 2006 | 09:05 AM
OUR97's Avatar
OUR97
I think you will have better luck with the water based paint. Mine has been there 2 years and no problems. Of course we don't get the heat like you do. We only have snow 300 days a year here. The rest are cloudy and damp.
Old Mar 27, 2006 | 10:33 AM
vetteshockandawe's Avatar
vetteshockandawe
Senior Member
Cruise-In V Veteran
Try Corvette Accessories Unlimited - www.cau-llc.com
Old Mar 27, 2006 | 11:46 AM
PierEagle's Avatar
PierEagle
Had to laugh when I saw your response. Back in the '80s I spent a summer in Buffalo. It lasted from Friday nite until Sunday morning.
Cheers
Old Mar 27, 2006 | 11:51 AM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
CAU is where I got Mag Red airbag letters.
Old Mar 27, 2006 | 12:10 PM
CorvetteGirl-NM
Thanks guys!! I just ordered the 3 decal special.... my 1st mod!
Old Mar 27, 2006 | 12:16 PM
Postergeist's Avatar
Postergeist
Be really, really patient when putting the letters on... and best not to do it after having a few. I used a tweezers to hold the letters with and a toothpick to manipulate them as needed. Oh, and be sure to follow their instructions as far as prepping (I think denatured alcohol and something else).... my first set didn't stick - had to order a second.
Old Mar 27, 2006 | 12:27 PM
CorvetteGirl-NM
Thanks for the tips, I'd hate to have them fall off right away
Old Mar 27, 2006 | 12:56 PM
Cruisin''s Avatar
Cruisin'
I have that good prep is the trick with any of this stuff. If you take your time to prep the areas correctly, you shouldn't have a problem the stuff peeling off.
Good luck and enjoy!
To Has Anyone Tried....
