lost key
Old Mar 27, 2006 | 08:01 PM
doug doo wop's Avatar
doug doo wop
Default lost key
Hi, how much is a key and fob for an '04; I lost my spare. Thanks
Old Mar 27, 2006 | 08:04 PM
Mitch.Shea's Avatar
Mitch.Shea
i got quoted 200 for the fob and 75 for the key at the local stealership but they jack up our prices so my guess would be half of that.
Old Mar 27, 2006 | 08:39 PM
rwlc5's Avatar
rwlc5
Hey Doug,
You can buy a replacement fob on ebay pretty cheap for an 04. Here is a link to one.
http://cgi.ebay.com/ebaymotors/NEW-0...QQcmdZViewItem
I have bought remotes for my vette, trailblazer & honda on ebay without any problem.
Bob
You just have to male sure that the number on the back matches the number on your other fob.
Old Mar 27, 2006 | 08:44 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
You can buy replacement keys from Ecklers, or Ebay - whereever you find the best price. You have to know the VATS code on the key. That's the little black chip. You will need a digital volt/ohm meter. You will have to read the resistance on both sides of the chip to determine which one you need. Then reference this list....
. VATS key codes
You need to read the resistance of the key. If you have a digital volt meter, set it on ohms mode and measure the resistance of the pellet on your key. Do a search on the web for "VATS" or "PASS-Key" for an explanation. The BCM is programmed for a specific resistance value. The BCM measures the voltage drop across the key pellet. If it is within +-10%, then the car will start.
The 15 resistor codes are:
Key# Value (Ohms)
1 392
2 523
3 681
4 887
5 1130
6 1470
7 1870
8 2370
9 3010
10 3740
11 4750
12 6040
13 7500
14 9530
15 11800
As far as the getting the key cut - once you have the right chipped blank, anyone capable of performing a two sided cut can cut the key.
For the fob - just make sure that one you buy matches the numbers found on the back side. They are NOT all the same. If you car is a later model - you will also have a 1 or a 2 on the back. You'll need to match that number with the one that you lost - as it corresponds to the memory position 1 or 2.
You should be able to do the whole thing on Ebay for under $50....
Old Mar 27, 2006 | 08:45 PM
doug doo wop
thanks Bob
Old Mar 27, 2006 | 08:46 PM
JustinSwinton's Avatar
JustinSwinton
go check out the corvette key! Cheaper than a whole new key/fob, and really nifty.
-Justin
Old Mar 27, 2006 | 08:53 PM
blacksedan87
-Justin
Sorry - but I have to disagree. You pay $132 for the CorvetteKey thingy, and it doesn't come with the circuit board for the fob - you have to provide that or I they will sell you one for $15 on an 01-04. You also have to still get the key cut....
I still maintain that you could get the whole deal for half on Ebay...
Old Mar 27, 2006 | 08:57 PM
JustinSwinton
And thats still more expensive than 200 for a fob and 70 for a key??
Old Mar 27, 2006 | 08:59 PM
Arcane1's Avatar
Arcane1
Supporting Tuner
Cruise-In VIII Veteran
St. Jude Donor '06-'07
I had to buy a #2 fob for 03 and it only cost me 45 bucks from the stealership as referred to here on the forum. As for the key I have no idea what that costs.
Arcane1
Old Mar 27, 2006 | 09:38 PM
doug doo wop
Originally Posted by rwlc5
Hey Doug,
Bob
Just ordered a fob for $21.44 but I still need a key. I appreciate Blacksedan's reply but sounds awfully technical and I don't have a digital meter. So what's another option, has anyone just ordered one from the dealer and how much?
Old Mar 27, 2006 | 10:07 PM
CORVETTE KEY's Avatar
CORVETTE KEY
132.99 gets you a key AND a remote !
Old Mar 27, 2006 | 10:39 PM
doug doo wop
I already ordered a fob so how much is a key and do they have to be programmed with that chip in it? Thanks
Old Mar 28, 2006 | 12:56 AM
CORVETTE KEY
No programming necessary but you will need to know what the Vats# is for your Corvette. It will be a number between 2-15 (i.e. 3,6,7,14... one of them).
Visit www.CorvetteKey.com for more info.
Old Mar 28, 2006 | 08:39 AM
Speckrig's Avatar
Speckrig
Recently ordered a key from dealer. $45.00.
FOB was $47.00.
Old Mar 28, 2006 | 10:15 AM
rwlc5's Avatar
rwlc5
Doug,
If you get your key form the dealer, they can tell which one you need by reading the chip on your other key, which they will need anyway in order to cut your new key. Did you lose your fob & key on Sunday at the show? Maybe someone found it and turned it in to Bob Bell.
Old Mar 28, 2006 | 10:30 AM
doug doo wop
Thanks for the info but where is the vats # located?
Old Mar 28, 2006 | 10:31 AM
doug doo wop
Doug,
No, I or SHE misplaced it about a month ago
To lost key
