Third brake light question
Old Mar 27, 2006 | 08:22 PM
shannanl's Avatar
shannanl
Default Third brake light question
Sunday I stopped by Auto Zone to pick up a 3rd brake light bulb or bulbs, not sure how it is set up. Mine are shot. They didn't have any info on the 3rd or high mounted stop light for a 97. The books and computer had nothing.
Any of you guys with parts manuals care to give me the part #? Also how do I change it? Do I go into the inboard tail light?
Thanks in advance for the help.
Old Mar 27, 2006 | 08:28 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
They are LED's - no bulbs.
Unless you have the means to replace (solder in) LED's, I believe you have to purchase the entire strip and replace it as a unit. I'm sure it was done this way because of the life expectancy of the LED's - so no cracks about stupid engineering!
Old Mar 27, 2006 | 08:32 PM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
I'm still certified ASE to deal auto parts by the way.
There's two ways to get the part you need.
1st: go to the stealership and apply for another loan.
2nd: Take the bulb out and take it to the auto store. Most bulbs (even from the factory) have the part number stamped on the brass portion of them or printed on the bulb itself. A majority of the companies that make the bulbs use the same part numbers, in fact. If you take one in to match it, the people at the parts counter can find the exact replacement or find one with the same specs. I used to do this all the time with my customers.
Over the years, GM hasn't deviated too much from what they have been using.
OOPS... just saw sedan's post. If they are LED's.. get a loan.
Last edited by DjCritterus; Mar 27, 2006 at 08:33 PM. Reason: Didn't see the previous post... and Mr. Bacardi isn't being nice.
Old Mar 27, 2006 | 08:56 PM
99vertnbm's Avatar
99vertnbm
It's not a LED. Just take out the right inside taillight, reach in, twist plug on third brake light, comes right out, pull out bulb. It's just a regular push-in type bulb but I cant remember the number. Any part store or Walmart has it. Pretty simple change. I put a Back-off flasher on mine. Maybe it will help to keep someone from rearending me. Flashes 4 times then stays on for 4 seconds, flashes 4 times and so on.
Old Mar 27, 2006 | 09:13 PM
Cajun99's Avatar
Cajun99
I don't know what kind of third-light is in your car but this is what is in the C5s...and it's not a push-in bulb...it's an LED package that cannot be bought at Wally World or AutoZone.
Picture credit to GBVette from his camera install page. This IS the same light assembly that was in my previous C5s too. How about posting a pic of your push-in bulb light
Old Mar 27, 2006 | 09:25 PM
sebringsilver97coupe's Avatar
uh yeah it is. all C5's have LED third brake lamps. the lp lights are regular bulbs, the tail lights are, but not the middle one. not sure why one would go out, its LEDs and they should last plenty long. try the parts for sale section, theres a bunch of wrecked parted out c5's out there.
Old Mar 27, 2006 | 09:35 PM
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
St. Jude Donor '04-'05-'06
If all of them are out I'd say check your connection.
Being they are LED's I highly doubt they are all shot.
Old Mar 27, 2006 | 10:10 PM
Mike Mercury's Avatar
Mike Mercury
huh ???
I know for certain that 2001 and newer are LED, cause I seen it with my own eyes.
I thought the CHMSL was LED even on the 1997 C5; but can only personally attest to 2001 and newer.
Changing the individual LED's is a chore, as the unit is sealed... one piece. Not make to be taken apart and serviced.
Old Mar 27, 2006 | 10:18 PM
Mike Mercury
Bill, If I can borrow the pic you posted...
the circled area is the most vunerable part of the C5 CHMSL. Those electrical "pins" are not metal pins... but extensions of the circuit board material of which the LEDs are soldered to. Being of that material, then will break off very easliy with any side loading. So be careful when plugging and unplugging the connector to the CHMSL.
(don't ask me how I know this )
Old Mar 27, 2006 | 10:22 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Correct in every respect. Definitely LEDs - definitely not incandescent bulbs.
Old Mar 27, 2006 | 10:53 PM
gknight's Avatar
gknight
I just today recieved my new brake light today, and the LED is built in. Now, how do you replace the whole assembly? Through the taillights? is it a pain in the a$$ or what?
Old Mar 27, 2006 | 10:58 PM
99vertnbm's Avatar
99vertnbm
Mines a '99 and it does NOT have LED. I have changed the bulb twice since I bought it. Maybe the newer C5 has LED but my 99 has a incandesent push in bulb (197 I think). I will get a photo tomorrow, for the nonbelievers.
Old Mar 27, 2006 | 10:59 PM
gknight's Avatar
gknight
Mine is a 2000 FRC.
Old Mar 27, 2006 | 11:04 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Call Gene@Karshop - get the whole thing in the neighborhood of $35 - $40. Remove an inside taillite, unplug the connector in the center, and loosen 2 nuts and you good.
Old Mar 28, 2006 | 12:46 AM
C5VetteLS1's Avatar
C5VetteLS1
St. Jude Donor '06-'07-'08-'09
97 thru 04 all have the same sealed LED units. Just go in through one of your inboard taillights with a 7mm socket and remove.
Old Mar 28, 2006 | 01:04 AM
C5BlkVette's Avatar
C5BlkVette
St. Jude Donor '03 thru '08,'16,'18,'21-'22,'24
My 97 is LED also. I highly doubt that GM would change it for 99 alone. A friend of mine bought one for $40, shouldn't be that bad!
Andy
Old Mar 28, 2006 | 03:24 AM
WWK888's Avatar
WWK888
This should be interesting...
To Third brake light question
Old Mar 28, 2006 | 03:35 AM
01QuickSilver's Avatar
01QuickSilver
I just want to know how he got his camera in there ????
Must have borrowed one from his proctologist.....
Old Mar 28, 2006 | 03:45 AM
nope. unless u have the one car GM screwed up on, the CHMSL is LED. get us a photo of this push in bulb brake lamp......
Old Mar 28, 2006 | 04:18 AM
01QuickSilver
What is a CHMSL?????
